Exedy clutch grind
Old Mar 7, 2021 | 11:41 AM
Benjiboy350z's Avatar
Benjiboy350z
Default Exedy clutch grind
Hi
I’ve recently had a lightweight flywheel and exedy clutch fitted to my 06 Rev up . It grinds when I’m changing up a gear . Garage is saying it must be the wrong kit (they ordered it) and are now saying they’re going try the old c and f if they can find it 🤦🏻‍♂️
it was supplied by a very reputable dealer. Does this sound right or could it be be poor fitting? I’ve had a mare with these lads
Old Mar 7, 2021 | 01:36 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Originally Posted by Benjiboy350z
Hi
Well, you, as the final and deciding point in this transaction have the right to have them make it right. Whoever screwed up by ordering OR delivering the wrong part is not your concern and putting your old parts back in is simply and utterly unacceptable. The shop needs to fix it and whatever the issue is with the part is between the shop and the supplier.
sgreb
Sep 26, 2011 04:46 AM
musubi
Feb 27, 2009 06:54 AM
Z-Lover
East Canada
Oct 14, 2008 08:30 AM
Z12350Z
Dec 23, 2007 09:00 AM
TheCajunStyle
Apr 24, 2006 08:01 AM
