engine shuts down when driving in rain or wet.
Old Mar 8, 2022 | 08:28 AM
Gtcinms's Avatar
Gtcinms
Question engine shuts down when driving in rain or wet.
Tried everything else so maybe someone has seen this problem before ..Iam trying to figure out why my sons 2005 350z will shut down when he is driving , but only if its raining or the roads are very wet like it just rained. almost every time it shuts off it will throw A P0335 code (Not Always, but most of the time) back history is crank sensor has been changed 5 times , fuel pump is new, Connector at the crank sensor was changed as was the maf sensor and the connector changed. The car was brought to Nissan they tried for 2 weeks and said they couldnt find a problem, Anyone have any other ideas on what else to try or have seen this issue? Thanks forgot to add this is an automatic trans car.
Old Mar 8, 2022 | 08:35 AM
jhc's Avatar
jhc
General & Tech Moderator
Question 1) Is the car wearing the lower under-tray under the engine?
Old Mar 8, 2022 | 08:49 AM
Gtcinms's Avatar
Gtcinms
No there is no tray under the engine , but it never had one and he has been driving like this for 3 years just started doing this a few months ago.
Old Mar 8, 2022 | 09:36 AM
travlee's Avatar
travlee
Master
sounds like corrosion is finally settling in
Old Mar 8, 2022 | 09:40 AM
jhc's Avatar
jhc
I regret losing interest in your problem so quickly but if you're still getting P0335 after 5 attempts to correct it perhaps you should re-evaluate the work that was done, maybe use OEM parts?
https://duckduckgo.com/?q=nissan+350...35&t=h_&ia=web
A good starting point when troubleshooting is asking, "What could have possibly changed since the car ran correctly?" Gl!
Old Mar 8, 2022 | 10:17 AM
Gtcinms's Avatar
Gtcinms
Well thank you for the attempt , And the parts are OEM that were replaced.. Car was driving great he left work one night and only made it 1/4 mile and the car shut down been chasing the problem after that ..But again thank you for trying.
Old Mar 8, 2022 | 10:28 AM
jhc's Avatar
jhc
Of course.
Perhaps someone with additional expertise can add some advice. Gl!
Old Mar 8, 2022 | 01:26 PM
dkmura's Avatar
dkmura
General & DIY Moderator
The underbody splash tray really does help keep the engine bay from getting soaked with water. You may need to replace those and the fender liners to keep the spray from getting up into the electronics. As a bonus, it will also stiffen and strengthen the front bumper section and keep your lights functioning properly.
Suresh Suwan
Oct 3, 2016 10:30 AM
chicharito16
Jun 2, 2014 08:13 PM
CDNZED
Jan 26, 2006 04:54 PM
hcwlsu
Jan 23, 2006 03:54 PM
Z8M
Jan 4, 2004 04:23 PM
