Does anyone have a NISMO LSD w/ no noise?
Originally posted by zillinois
Do you have the NISMO LSD? Is it quiet?
If so, what are your recommendations for setup and break-in?
Are they all noisy? Or can someone recommend a different kind.. Kaaz or Cuzco. This is my next mod along with the ring and pinion and I would really prefer to keep the popcorn popping noises reserved for movie night. Thanks for any help.
I do !!!
I broke it in with the Nismo oil, than changed it out with Valvoline synthetic mixed with (GM Whale Sperm) GM Differential additive got rid of most of the noise and my dif is set at the max setting. Im in IL if you want to go for a spin
Vendor - Former Vendor
any aftermarket LSD you go with will be noisy, or at least noisier than stock. Sometimes you can get them to be a little more quiet depending on what lube you use, but it only helps so much. People just don't seem to understand that when you want perofrmance, you have to make a sacrafice in noise etc....
ok guys just installed my nismo lsd i love it but the sad thing is i got it used from z1auto.com which is ok but didn't come with instructions so i don't know what setting it was on 1.5 or 2.0, and i don't know what the lockup was if it was 60 80 or 100% I was driving with it last night and well jerks a little when i make turns would that mean its set on 2 way or is that normal and is it suppose to be that loud when its cold cuz it sounds like alot of metal grinding on the straight away its amazing especially with the spl aluminum bushings
It's set @ 1.5 The lockup is factory set @ 60% also(the lowest:quietest setting)
After the break-in get yourself some Motul 90. No matter what though, in the cold it will be noisy. When it warms up it helps but no matter what parking lots will borderline embarrassing.
If my Z was my DD I wouldn't use the nismo but its not so I don't care
lol yeah, when i had mine i would have people stopping me and telling me that my tires were locking up. haha going thru the local sonic with all the honda guys, looking at me crazy.
seagrasser
Oct 11, 2015 03:27 PM
ekim952522000
Mar 29, 2006 10:33 AM
