engine covers
Old Apr 8, 2004 | 05:06 PM
blackmumba's Avatar
blackmumba
Default engine covers
i want to try to paint my engine covers super black gloss but im wondering what kind of paint can i use to stick to plastic and to hold up to the heat. and what kind of surface preperation needs to be done or if i should just take them to get powder coated????any suggestions.
Old Apr 9, 2004 | 07:27 AM
BrickydZ's Avatar
BrickydZ
http://www.350zfrenzy.com/forum/show...&threadid=2389
Try this post on 350zFrenzy.
This guy does great work and has a list of some materials.
You can glean alot of information from his photos and descriptions.
He painted mine, shown below.
Old Apr 10, 2004 | 01:21 AM
12SecZ's Avatar
12SecZ
Yeah he is the man, I would vouch for him any day.
Old Apr 10, 2004 | 02:36 AM
Z CRUZN's Avatar
Z CRUZN
Default For sure!
Same as above!!! He's a true artist.......
Old Apr 10, 2004 | 09:24 AM
CTZ's Avatar
CTZ
I couldn't agree more. Worth every penny!
Old Apr 10, 2004 | 11:08 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Rob is DA MAN!
Old Apr 10, 2004 | 12:47 PM
mode101's Avatar
mode101
Originally posted by Dr Bonz
Rob is DA MAN!
Looks sweet.. is brickyard gone in 04 ?
Old Apr 10, 2004 | 02:41 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yep.
Old Apr 11, 2004 | 08:49 AM
CaneZMD's Avatar
CaneZMD
I agree, he does awesome work. I've read all 500+ posts on frenzy about this.
But, I still can't find the will to drop $400 to get my covers painted. I want to try to paint them myself and save my money for something like a Vortech.
$400 is like 50 hours of work at my residents salary.
Old Apr 11, 2004 | 12:41 PM
Speedracer's Avatar
Speedracer
Easy DIY mod......
1. Remove all plastic/metal parts you want to paint.
2. Wash all parts and scrub with Brillo steel wool/soap pad for 10 minutes for each part. Make sure to get every little crack and corner. This is the key step to the whole process. It will remove the oils from the surface of the plastic as well as finely roughing the surface for painting.
3. Prime with hi-temp primer. Use 2-3 coats. Available in most auto-supply stores.
4. Paint with hi-temp engine paint. You don't need the engine block paint which is rated upto 1200 degrees. This is overkill. Your color selection is limited, however. I've seen red, orange, black, silver, aluminum, chrome finish. Anything else and you will need to take to a body/custom paint shop.
Good luck
Old Apr 11, 2004 | 12:43 PM
DavesZ#3's Avatar
DavesZ#3
You need some Bulldog adhesion primer, that helps regular paint stick to plastic. You can get cans of spray that match the Z's colors from www.towerpaint.com. All you need is the paint code to order it.
Old Apr 12, 2004 | 11:14 AM
blackmumba's Avatar
blackmumba
somebody told me i could also use the touch up body paint from auto zone and then i could buff it and polish it
Old Apr 12, 2004 | 02:12 PM
BrickydZ's Avatar
BrickydZ
Default Try it
Go ahead and try it. What do you have to lose.
But try the battery cover first. Cost $11.00 from the dealer to replace. Finish it up and drive it a few weeks, and see how the heat effects it. Then do the other two.
Your choice of Gloss Black will make it easier since you can go with a generic black and not Nissan OEM colors like we Brickyards did.
I too was sceptical about the cost. But I did it and i have never regreted it. Rob did such great job and well worth the money.
Old Apr 12, 2004 | 04:33 PM
ZxRage's Avatar
ZxRage
I agree, Rob does great work!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
ablaine
Nov 29, 2016 10:13 AM
Fixxxercask
Nov 9, 2015 11:10 AM
