using oil after 4k
Old Apr 13, 2004 | 05:55 PM
350ZTN's Avatar
350ZTN
Default using oil after 4k
haven't had an oil change yet, been about 4-4500K miles since the last change and am a quart low...should I be concerned? I don't think I should be burning that much.
Old Apr 13, 2004 | 06:00 PM
Dissolved's Avatar
Dissolved
I talked to like 4 or 5 different dealership's service departments regarding oil consumption. All said burning up to a quart every 2500-3k was normal.
Also take into consideration the crappy design of the dipstick, it leaves error for crappy readings. I bet you didnt really lose a quart.
By the way, if you use synthetic oil with a decent filter you should be fine. I'd change oil soon though.
Old Apr 14, 2004 | 03:16 PM
350ZTN's Avatar
350ZTN
what type of synthetic oil and filter are recommended?
Old Apr 14, 2004 | 03:53 PM
Dissolved's Avatar
Dissolved
mobil 1 5w30 and either Nissan oil filter or Mobil 1 filter is all I use
Old Apr 14, 2004 | 09:21 PM
GY-Z's Avatar
GY-Z
i recomend motul 300v 5w40 for track use.
great oil, just a little pricy.
Old Apr 21, 2004 | 05:01 PM
Duke407's Avatar
Duke407
WOW! Nice pic (avitar)!
Old Jun 6, 2004 | 10:09 PM
jreiter's Avatar
jreiter
Just saw this old thread, and wanted to toss in some info I got today in case anyone else searches it up like I did.
I talked with the California Motul distributor/rep today for a good hour or more and chatted about oil and all sorts of things. He said the 300v oil is by far the best stuff you can get for very hard driving, but he was very adamant about changing at 3500 miles and not going futher than that. Apparently the 300v (despite it being just about the best pure synthetic you can get for racing) lacks the additives that other oils have which allow them to go for long miles between changes. So, it's the best oil you can get as far as lubrication, but you must not run it longer than 3500 miles or so. And it's really expensive.
As far as normal daily driving oil for normal cars under most conditions, he actually recommended the 8100 series instead. Cheaper and goes many more miles. It's the equivalent of other oils like Mobil 1 synthetic, Redline, etc. (But better, of course.) In particular, he recommended the "8100 E-Tech lite 0w-30" for the Z. (They don't have 5w-30 in that line, but he said 0w-30 was perfectly okay.)
Anyway, just wanted to pass this along. I cannot confirm nor deny the accuracy of this info. This is jus what the rep told me.
Old Jun 6, 2004 | 10:32 PM
GY-Z's Avatar
GY-Z
this is somehow correct.
i know the 300v isn't good for a long mile.
i personally changed it every 2 track days, or 3 months if the millage does not reach 3000km.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
