Dash Lights stayting on, Please Help!
Old Aug 29, 2004 | 10:05 AM
Tfasano's Avatar
Tfasano
Default Dash Lights stayting on, Please Help!
I just started my car and the Brake, Slip and VDC off lights are all on and staying on. I tried restarting the car and nothing. Then I tried resetting the computer and nothing. Anyone have this happen before? What should I do?
Old Aug 29, 2004 | 10:11 AM
Duflacci's Avatar
Duflacci
Default Re: Dash Lights stayting on, Please Help!
try driving it about 100 feet and see if it resets
Old Aug 29, 2004 | 10:12 AM
Duflacci's Avatar
Duflacci
try disconnecting the battery for 5-10 minutes
Old Aug 29, 2004 | 10:47 AM
huducks's Avatar
huducks
same thing happened to my friend, he went to the dealer and all they did was disconnect the battery for 5 mins.
Old Aug 29, 2004 | 12:53 PM
Tfasano's Avatar
Tfasano
Default Re: Re: Dash Lights stayting on, Please Help!
I just tried the battery disconnect and it didn't work either. It sat for about 20 minutes disconnected. I have it off again and will let it sit longer. Anyone know WTF this is? The manual says that if the slip and vdc lights come on together that something with the vdc is malfunctioning. But my brake light is on as well. hmm, not good!
Old Aug 29, 2004 | 04:29 PM
huducks's Avatar
huducks
hmmm.. check all of ur wheel speed sensors c if ne of them came loose. happened to one of the cars b/c after lowering the car we mounted the sensors the wrong way onto the strut body. after driving for a couple weeks his vdc, slip, and brake light came on. we noticed the connectors came loose. good luck.
Old Aug 29, 2004 | 04:31 PM
Tfasano's Avatar
Tfasano
Thanks. What does a wheel speed sensor look like? I was also told it could be the brake sensor under the steering wheel.
Old Aug 29, 2004 | 05:28 PM
gotagetmyZ's Avatar
gotagetmyZ
You wouldn't have disconnected the plugs in back of the brake pedal to do standing burn outs would you? If so, maybe they weren't plugged back in properly.
Old Aug 29, 2004 | 08:40 PM
huducks's Avatar
huducks
did u try driving around after disconnecting the battery?? if i remember correctly the g/z has sensors in both front wheels. if u look there is a wire running from the hub of the wheel to the strut body to the inner fender well. the connector being on the inner fender well and the sensor being in the hub. its the only wire there, dont get it confused w/the brake line. but the brake line is easy to spot its much thicker and runs directly into the brake caliper.
Old Aug 29, 2004 | 09:36 PM
Zmego1985's Avatar
Zmego1985
When my 2002 maxima blew a maf sensor it did that. But if its driving fine it cant be that. So i would just keep the battery off for 24 hours.
Thanks Glen
Old Aug 29, 2004 | 09:46 PM
AmyCroft's Avatar
AmyCroft
Default Sounds Like the Connector to th Mass Air Flow sensor
Sounds Like the Connector to the Mass Air Flow sensor
Has been Shorted to ground - ( of course not install backwards.. )
There is an arrow of air flow.. Duh !
Is your machine Stock - or have after market intake?
Cheers Amy -
Old Aug 30, 2004 | 02:43 AM
Tfasano's Avatar
Tfasano
Default Re: Sounds Like the Connector to th Mass Air Flow sensor
Cheers Amy -
Not stock, see sig
Old Aug 30, 2004 | 05:16 AM
spdu4ia's Avatar
spdu4ia
mine did that with the MAF.. took it to the dealer and had them remove the code and its all good now.
Old Sep 5, 2004 | 05:08 AM
Tfasano's Avatar
Tfasano
Washed the car yesterday and noticed that one of the wheels was filthy, so I checked my brake fluid level and sure enough it was nearly empty. Turns out I must have loosened up the brake line when I installed the spacers. I tightened up the bolt and added fluid and wallah the lights went off.
Thanks for your help everyone!
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
