-- Techno Square ECU --
Old Sep 21, 2004 | 01:57 AM
FastWRX's Avatar
FastWRX
Question -- Techno Square ECU --
Anyone here know if the Techno Square ECU is worth it ?? They claim that it "raises the stock rev limiter, changes timing and fuel curves to provide more horsepower and torque."
Old Sep 21, 2004 | 02:41 AM
zillinois's Avatar
zillinois
Probably not worth it by itself. If you have a bunch of other mods it is worth it because your car will run right.
Old Sep 21, 2004 | 04:09 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I have a bunch of bolt-ons on my car, they caused me to run really lean over 15.1 A/F's...I sent it to Technosquare with my dyno plots and I gained 8whp and 13 w ft lbs and my a/f is a perfect 13.1 across the board, so in my case it was WELL worth it, I was super happy with the results, car runs much stronger, and the TQ increase was nice.
Old Sep 21, 2004 | 04:58 AM
mofoz's Avatar
mofoz
they dont have an 04 version yet do they?
Old Sep 21, 2004 | 05:32 AM
signalpuke's Avatar
signalpuke
nah they still have to crack the ecu
Old Sep 21, 2004 | 07:10 AM
Sponge's Avatar
Sponge
I've heard from TS that they can re-flash up to 10/04 manufacture date. I'd call TS to conform. I'm going soon for the re-flash I want the car to be running in the correct a/f range. Everything else (power, rev/speed limiter removal, etc.) is just gravy.
Old Sep 21, 2004 | 01:29 PM
ZinMiami's Avatar
ZinMiami
I believe you meant 10/03 since its not 10/04 yet.
Old Sep 21, 2004 | 06:44 PM
Enron Exec's Avatar
Enron Exec
Anyone tried: http://www.alteredatmosphere.com/main.asp
Old Sep 23, 2004 | 09:02 AM
ihatethatbobbarker's Avatar
ihatethatbobbarker
i bet tadashi is a better programmer
Old Sep 23, 2004 | 09:09 AM
signalpuke's Avatar
signalpuke
is mj a robot
Old Sep 23, 2004 | 11:37 AM
ihatethatbobbarker
who?
Old Sep 23, 2004 | 02:18 PM
Sponge's Avatar
Sponge
doh...you are correct sir LOL
Old Sep 23, 2004 | 05:47 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Altered Atmosphere uses the TS software....everyone who flashes a Z ecu uses TS software, which itself is Techtom software (same software everyone in Japan uses who offers a "tuned rom" ecu for the Z).
I had my car flashed by Mike.....got very good gains and will likely go back when the new heads are done
Old Sep 23, 2004 | 07:21 PM
Donald0730's Avatar
Donald0730
i think there's a way to check by looking for some numbers/letters on the ECU or price sticker.
Old Sep 23, 2004 | 08:31 PM
all_bark's Avatar
all_bark
I got it and as others have said. I have a lot of bolt on mods and the air/fuel was F'ed up. Very lean, so I took it to tadashi and now I am straight across the line, very nice, with a few extra ponies to boot!
for you, wait till you are FINISHED modding and then go get it...
Old Sep 24, 2004 | 08:51 AM
Mr Twisted's Avatar
Mr Twisted
2004.5 ecu and later wait should be over Tadashi gets back from Japan at the end of the month. Now is the time to start the modding up again.
Old Sep 24, 2004 | 09:03 AM
UF350's Avatar
UF350
I have the TS reflash and personally I think its one of the better mods. It dropped mt 1/4 time more then anything else. The extra 500 RPM really help.
Old Sep 24, 2004 | 09:45 AM
ZRAYGO's Avatar
ZRAYGO
what do u think it will do with the greddy tt? will it work?
Old Sep 24, 2004 | 10:39 AM
ihatethatbobbarker
parts of it will definitely, such as the higher redline and such.
Old Sep 24, 2004 | 12:57 PM
G35_CP's Avatar
G35_CP
Default Optimal A/F ratio with mods
I am going to Dyno my car on Saturday. What A/F ratio would indicate the car is running lean? What are the ranges? I read on the TS website after they flash the ECU the A/F will be 12.5 across the rev band. Is that the optimal A/F for our cars? I am just trying to decide if I need the Flash done. Has anyone purchased another ECU and flashed that instead of their original one? The Infiniti mechanic told me that there might be a problem re-flashing the original code from a backup copy. Any truth to this? Thanks for the help.
