Changing the Differential / Transmission Oil
Old Apr 24, 2009 | 01:58 PM
  #341
pony_killer's Avatar
pony_killer
Arada ninda apa
just did this today with motul gear 300...used a brand new washer for the tranny drain bolt and the old one for the diff because nissan gave me the wrong washer for the rear. drove about 50 miles with no problems and VERY smooth shifting. Happy Motul customer here!
Old Apr 25, 2009 | 06:18 PM
  #342
35Z's Avatar
35Z
So did the tranny upshift/downshift in all gears better with Motul than previous tranny fluid (what was in the tranny before)? What was the outside temps?
Old Apr 26, 2009 | 08:29 AM
  #343
drewk's Avatar
drewk
Guys, I have a slight issue. I have the turbonetics kit on my car. Changed differential fluid, transmission fluid, motor oil and drive belts...
After doing all that, the car seems extremely sluggish, heavy and slow. I used amsoil 75w90 for the transmission, 75w90 severe gear for the diff with sliplock...
Does anyone have any idea as to what it could be? Any help would be greatly appreciated.
edit: I have an 05 350z Manual Transmission.
Old May 25, 2009 | 08:05 PM
  #344
Steve-O Z33's Avatar
Steve-O Z33
My car has been notchy since switching to Royal Purple in the trans. I'm switching to Motul 300 soon. Just ordered it.
I can't downshift to 1st when moving sometimes if it's cool. It's horrible. Royal Purple is crap.
Old May 25, 2009 | 08:37 PM
  #345
Monsta's Avatar
Monsta
2305
Is that a limited slip additive? If so, that may be your problem. To change viscus limited slip fluid, you would have to remove the diff cover and get to the casing INSIDE. The gear oil you changed is only lubing the ring and pinion gears. Maybe the additive is thicking up the gear oil when it heats up.
2337
Read a lil info on Amsoil about the Slip Lock and what I wrote above I believe is true. Factory 2003 Performance limited slip diffs are viscus type. The friction modifier you put in is for mechanical limited slip diffs. Change the fluid again without the Slip Lock.
Google limited slip diffs and you should get some explainations between the differential types.
Old Jun 10, 2009 | 07:36 AM
  #346
FoxIslandZ's Avatar
FoxIslandZ
Very helpful write up. Thanks Monsta. Did mine last night. Hardest parts were getting the car high enough and breaking loose the tranny fill plug.
How important is it to use a torque wrench? I figure get it adequately tight so the plugs can't come out but not so tight I can't get them off in 3 years without pulling a muscle.
Old Jun 10, 2009 | 05:50 PM
  #347
Monsta's Avatar
Monsta
Not a problem.
I put them on gutntight! Be careful not to torque them TOO hard cuz the transmission is very soft.
Old Jun 19, 2009 | 08:26 PM
  #348
kennedy's Avatar
kennedy
Got the Amsoil for the engine today. Going to be picking up the trans and diff oils tomorrow going todo the Redline Trans Cocktail, and amsoil for the diff 80-90.
Old Jun 21, 2009 | 07:27 PM
  #349
Nismospeed4life's Avatar
Nismospeed4life
Great thread! It took me all day to read it all... However, I am still split between Amsoil & Motul. Which brand should I go with? I was leaning more towards Amsoil even though I'm running Motul for my clutch fluids.
Any suggestions would be apreciated.
Old Jun 22, 2009 | 02:34 PM
  #350
drewk's Avatar
drewk
Originally Posted by Monsta
2305
2337
Yes, that is a limited slip additive. I went back to stock trans and diff oil, (although the amsoil Tech said it wouldnt make a difference) And the car went back to normal, alot more smooth.
Thanks alot for your help...
Old Jul 4, 2009 | 06:51 AM
  #351
tywinter's Avatar
tywinter
I changed my gear oil today and used Royal Purple.
It is a GL-5, as well as a GL-4 rated oil. I chose it because it was the only Synthetic I could find local that did not have sulfur in it. (I wanted Redline...but it's not sold within a 40+ mile distance from my house and I'm impatient) From searching many other sites, I have found that most GL-5 rated oils contain sulfur and that is the additive that is bad for the synro's.
It did make the rear quieter, time will tell if I made a good or bad choice.
Old Jul 9, 2009 | 02:51 PM
  #352
03aeroZ's Avatar
03aeroZ
Ok....have read all 19 pages, and haven't really figured out which diff fluid to go with: Motul, Redline, or Amsoil?
I have a 2003 touring that is never tracked or anything. Looking at the Amsoil....any reason to go with the others or is it more personal preference?
Also, it looks like we don't need the LSD additive, correct?
Old Jul 10, 2009 | 06:40 PM
  #353
Nismospeed4life
I went with Amsoil and I'm loving it! And yes, no additive on LSD.
Old Jul 10, 2009 | 06:45 PM
  #354
03aeroZ's Avatar
03aeroZ
Thanks. That was my thought. Was leaning more towards Amsoil anyways, just didn't know about the additive.
Old Jul 10, 2009 | 06:56 PM
  #355
Nismospeed4life
Make sure that you get the crush washers from dealer just to be on the safe side.
Old Jul 10, 2009 | 06:57 PM
  #356
03aeroZ's Avatar
03aeroZ
Got em already!! Thanks....can't wait to get stinky!
Old Jul 17, 2009 | 08:12 PM
  #357
03aeroZ's Avatar
03aeroZ
Put in 2qts of Amsoil 80w-90 in the diff tonight....wasn't paying attention and scratched my head. Now I stink like holy hell!!! That old stuff was just fried too.....60k on it! Will be making this regular maintenance now. SUPER easy with the pump on the Amsoil web site.
Old Aug 1, 2009 | 05:47 AM
  #358
cferraro85's Avatar
cferraro85
has anyone used the genuine nissan synth gear oil. 75w-140 found here:
http://www.mynismo.com/products/?id=4608
Old Aug 29, 2009 | 06:02 PM
  #359
johndoesdamage's Avatar
johndoesdamage
I searched and couldnt find the answer. Can you use another oil besides the jmatic one for auto's?
Old Aug 29, 2009 | 07:57 PM
  #360
binder's Avatar
binder
Originally Posted by chrisjersey06
Just did this today, what a pain in the ***, haha.
2 quarts Redline diff fluid
2 quarts Redline MTL
2 quarts Redline MT-90
($75 shipped from Amazon.com)
4 new washers from Nissan ($13.78 w/tax)
why did you use 2 quarts MTL and 2 quarts MT-90? why not just all MT-90?
is the motul THAT great? it's double the cost of everyone else. 20$ a quart! that's just nuts.
