Changing the Differential / Transmission Oil
Old Nov 25, 2010 | 03:33 PM
  #461
Shawz1102's Avatar
Shawz1102
^^ thanks !
what diff oil are you guys using to change the diff for those with no lsd?
for non-synthetic, what is the mileage before the next change? what about for synthetics?
Old Nov 25, 2010 | 06:21 PM
  #462
Z1NONLY's Avatar
Z1NONLY
Originally Posted by Shawz1102
^^ thanks !
When I got my Quaife installed, the shop put in Royal Purple 75w 90 and I have been replacing the diff fluid with the same stuff about once a year / ~8k miles.
(But I track my car a lot, so I do stuff more frequently than I would for a street-only car.)
I don't even need a pump for the diff. I just put the tip of the bottle in and squeeze the fluid in.
Old Dec 2, 2010 | 03:42 PM
  #463
Shawz1102's Avatar
Shawz1102
^^ hey are you unable to recall what the name of the pump is at all? i went to autozone but unfortunately they dont have anything that looks like that...
Old Dec 2, 2010 | 07:21 PM
  #464
VQdriver's Avatar
VQdriver
Use your imagination. Any fluid transfer pump will do! Try another store or the grocery store for a sauce pump someone posted earlier about. I used a cheap $5 one from harbor freight. It works too.
Old Dec 3, 2010 | 12:27 AM
  #465
Shawz1102's Avatar
Shawz1102
^^ thanks... found the exact same one at pep boys... but man that thing is a PITA to pump... when i pump it, there's like a strong resistance, so i have to pump it harder... a dam 2 quart took me an hour just to pump...
i tested water and it pumped so easily... im guessing it's because oil flows slower... anyone encounter this as well?
Old Dec 3, 2010 | 06:30 PM
  #466
jasongME's Avatar
jasongME
Viscosity.
Old Feb 5, 2011 | 10:23 AM
  #467
srsairbags's Avatar
srsairbags
anyone use this ?
http://www.youtube.com/watch?v=3xk-o3UB-eI
Old Feb 5, 2011 | 10:28 AM
  #468
SlipZ's Avatar
SlipZ
Great product!!!, thats what i have right now!!!..it doesnt hurt either that redline oil is only 20 miles away from me!!..
Old Feb 5, 2011 | 05:27 PM
  #469
ian99rt's Avatar
ian99rt
Just bought some from ConceptZperformance.com.... Cheapest source possible.
I have not changed the tranny fluid yet b/c my cars at 41k miles, but it'll be going in when i do my next oil change at 45k.
Originally Posted by srsairbags
Old Feb 14, 2011 | 09:17 AM
  #470
kamz's Avatar
kamz
Changed the diff and tranny fluid this weekend. Thanks for the DIY. My lesson learned is to get the pump gun. That stupid suction pump was a PITA and tiring. I even broke mine and had to go out for another one and this time I decided to get the pump gun. $10 from harbor Freight and was so much easier. Fill it up and shoot the fluid in.
Old Feb 16, 2011 | 07:01 AM
  #471
VQdriver's Avatar
VQdriver
I've been using Redline MT-85 since this past Thanksgiving and it's working great. Anyone know where I can get an exact 80W-90 full synthetic gear oil for the diff? Right now I'm still using cheap, but effective Castrol Hypoy-C (conventional).
Old Mar 1, 2011 | 05:12 AM
  #472
dudegetalife's Avatar
dudegetalife
Originally Posted by Diesel350
I just went ahead and bought the Valvoline 80w-90 gear oil from Autozone for my differential. Why pay $20/qt for Redline when you can buy this for $6.00/qt? You can't beat that!!
while reading this i found out that this is just regular oil not synthetic and you can get a gallon for 15 at oreillys if your cheap enough part number is 832 val
gonna try royal purple we will see how it works out since i'm in texas and once a year maybe we will get into the teens.
Old Mar 10, 2011 | 06:51 PM
  #473
TheWan's Avatar
TheWan
anyone have any form of feedback with Mobil 1 synthetic 75w90 on LSD?
Old Mar 15, 2011 | 01:37 PM
  #474
Bevo's Avatar
Bevo
I use Castrol Syntec Full Synthetic Gear Oil 75W90. I could never find it in stores, always get it from Amazon.com.
Old Mar 15, 2011 | 01:46 PM
  #475
Zedhead07's Avatar
Zedhead07
Recently used Royal Purple Max Gear on the rear diff and factory Nissan MTL for the 6MT. Got bout 500 miles on the new change and trany shifts smoother. Bout the only difference felt. Maybe a slight MPG increase. Hard to tell she drives it like a Z should be driven. Think the synthetic is a "piece of mind" thing IMO.
Old Apr 25, 2011 | 09:49 AM
  #476
350ZZJoe's Avatar
350ZZJoe
This is exactly what I did last friday. RP in the diff and Nissan MTL in the transmission. Only maybe 100-200miles but I can definitely feel the smoothness in the transmission. Before, when the fluid was at full temp, shifting was very notchy feeling but now with the new fluid it feels great.
And I used to get a random howling noise from the rear when the car was cold (I assumed maybe it was the diff?) but now with new fluid I havn't heard it at all.
Joe,
Old Apr 25, 2011 | 01:18 PM
  #477
sssmasss's Avatar
sssmasss
lately i have been experiencing slippage. I changed my transmission like a year ago and it was fine until lately when i step on the gas and the car is not moving. it has a slight delay before it accelerates. anyone experiencing this ever?
Old Apr 27, 2011 | 07:44 PM
  #478
VQdriver's Avatar
VQdriver
Maybe it's clutch or hydraulic related and not due to the gear oil.
Old Jun 7, 2011 | 10:42 AM
  #479
dudegetalife
how often do you change tranny fluids in an auto 80k right?
Old Jun 15, 2011 | 02:58 PM
  #480
s31t8n8's Avatar
s31t8n8
So i just finished replacing my diff fluid and I found an easier method thanks to the guy at advance auto. I went there to pick up a pump and he told me that he use to work on the Z and knows an easier way to fill the diff without using the pump. If you take the spare tire out you'll notice there is a round black rubber piece under it. If you pop it off you can run a tub through the hole down to the fill hole. All you have to do then is put one end into the fill hole and stick a funnel on the other end and then just pour the diff fluid through the trunk. There is no need to lift the car up and it fills the diff quickly without any mess. Unfortunately I didn't take any pics but it's not hard to find the rubber plug. It only takes like 10 mins to fill the diff and all you have to do is just stand there an pour.
