Homemade Catch Can
Old Apr 6, 2007 | 07:43 PM
  #41
Quamen's Avatar
Quamen
I don't know if you would really consider my oil catch can to be "homemade" since I cnc'd it but here is a link to it:
https://my350z.com/forum/showthread....20#post3566220
Old Apr 14, 2007 | 03:06 PM
  #42
Dirty Dave's Avatar
Dirty Dave
Originally Posted by Zivman
The catch install is VERY easy. Just splice it inline with the PCV return:
Is there any other vacuum lines that should be addressed other than this one ?
Old Apr 15, 2007 | 08:03 PM
  #43
i8acobra's Avatar
i8acobra
Nope. I've never had any oil problems with the hose on the driver's side.
Old Apr 20, 2007 | 10:26 AM
  #44
MUZZY's Avatar
MUZZY
now how those this work in FI? I understand the whole concept for NA but once you are boosting in a FI Z dosnt the air from the line from the manifold start going backwards and push air into the case ware the "vapors" are coming from? im pretty sure that is not a good idea, em I right? can someone with better knowledge chime in please? I know I want one and allot of FI cars have catch cans but how it works during boost vs vacuum surpasses me.
Old Apr 20, 2007 | 11:26 AM
  #45
gringott's Avatar
gringott
We are talking about "blowby" here, crankcase vapors.
Old Apr 22, 2007 | 01:02 PM
  #46
XuperXero's Avatar
XuperXero
Bought all my stuff, I came upon a confusion when installing. I noticed when I opened the cap, I saw the outlet/inlet to be different designs. Which way are we suppose to route it to?
I'm guessing crankcase to the flow as show in attached picture then to lower plenum... since I looked into the hole and it points straight down. The OP routed it the other way though.
*note* one nozzle is shorter than the other
Old Apr 23, 2007 | 10:01 AM
  #47
gothchick's Avatar
gothchick
Update:
Hi Guys~ I did this mod this weekend per the above DIY instructions. Parts cost about $25USD at Home Depot, fuel injection line was a couple bucks at Auto Zone, and took me about 45 minutes to fabricate & install (I'm sure someone with more experience could install it faster). So far it's working great.
Attached Thumbnails Homemade Catch Can-dsc01890r.jpg   Homemade Catch Can-dsc01891r.jpg   Homemade Catch Can-dsc01902r.jpg
Old Apr 24, 2007 | 02:16 PM
  #48
MUZZY's Avatar
MUZZY
um so what happens when the vacuum line becomes boosted? is it ok to not allow the crankcase to breath?
Old Apr 26, 2007 | 12:23 AM
  #49
i8acobra's Avatar
i8acobra
Air comes out of the crankcase, goes through the can and out to the plenum. You want the arrow on the can (there should be an arrow stamped on top of the can) to point towards the plenum. The arrow indicates the direction of air flow.
Old Apr 26, 2007 | 11:47 AM
  #50
XuperXero's Avatar
XuperXero
oops... I mounted it in reverse then..
But it seems to collect oil fine.. should I even bother switch back around?
Old May 3, 2007 | 02:49 PM
  #51
gothchick's Avatar
gothchick
You're probably okay... Might wanna keep an eye on it to make sure though.
Old May 16, 2007 | 03:13 PM
  #52
gothchick's Avatar
gothchick
My catch can didn't seem to be catching much oil, so I thought I'd try an upgrade. I put some coarse stainless steal 'pot scrubber' mesh in the can to give the oil something to condense on. It seems to be catching more blow-by now...
Old May 16, 2007 | 10:43 PM
  #53
XuperXero's Avatar
XuperXero
Just wondering, how much oil are you guys collecting from this so far? I get about half full every 2 or 3 days. This is without steel wool mesh too. Am I collecting too much?
Old May 17, 2007 | 12:03 AM
  #54
Sisith's Avatar
Sisith
I get a ton of oil too...im wondering if thats a bad thing. I just removed my plenum again and it reeks of fuel and oil and is still puddling up
Old May 17, 2007 | 12:21 AM
  #55
Eazzy's Avatar
Eazzy
Originally Posted by gothchick
I thought I'd try an upgrade to the DIY Catchcan. I put some coarse stainless steal 'pot scrubber' mesh in the can to give the oil something to condense on. It seems to be catching more blow-by now...
Best to use it ---Its Name Brand is "Chore Boy" and sold in all Grocery stores or Wal Marts---Comes in Stainless or Copper ---Function is never Ghetto------20" Spinners are Ghetto
Old May 17, 2007 | 05:51 AM
  #56
Sasha350's Avatar
Sasha350
I have the same catch can (actualy it's the larger version of the can with the bottom release valve) and it works fine, i empty it about every 3 weeks, or whenever it gets about half way full. I put about 60 miles on the car every day so that gets to be around every 700-900 miles.
As far as the steel mesh, isn't there a danger that small piece of this steel mesh will break off and gets sucked back into the engine ?
I imagine that could cause some damage ?
Old May 17, 2007 | 06:07 AM
  #57
Motormouth's Avatar
Motormouth
do aftermarket catch cans catch this much oil? can any owners chime in as to how much? to be getting that much oil seems like an issue.
Old May 17, 2007 | 06:26 AM
  #58
Mike Wazowski's Avatar
Mike Wazowski
the container on this holds less than 1/2 of an oz. so it really isnt very much oil
Old May 17, 2007 | 06:29 AM
  #59
Motormouth's Avatar
Motormouth
ah.
Old May 17, 2007 | 09:06 AM
  #60
Eazzy's Avatar
Eazzy
No and if in a 1,000,000 to 1 chance it did it would cause no damage whatsoever
