Assembly of my new Built Short Block
Old Oct 28, 2007 | 10:11 AM
  #161
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by rrmedicx
Well thank you for correcting me. I appreciate the info. I can't recall where I read it, if it was in a magazine or maybe here, but I was pretty sure it came from the skyline. Either way, its a Nissan development and its much better than the original.
Thanks Adam.
no sweat - actually no one really knows the difference between a revup pump and a std. one, it just seems a natural that people would fit the revup, which comes on a car that when std. has a higher redline than the original motors, when doing a built motor. For all out HP and reliability, nothing beats the GTR N1 pump for the VQ, which is here:
http://www.z1auto.com/prodmore.asp?m...ine&prodid=920
Old Oct 28, 2007 | 02:01 PM
  #162
rrmedicx's Avatar
rrmedicx
Only about 200 miles to go. Gotta drive tonight.
Old Oct 31, 2007 | 03:59 AM
  #163
rrmedicx's Avatar
rrmedicx
Just finished installing the upgraded waste-gate springs yesterday and boy, or boy, was that a beatch!!!!!!!!
I had to start by removing the framing support bar (below the cross-member) because the waste-gate relocation kit is such a pain in the **** to reach, I thought I could simply push the springs up and into place then secure the waste-gate caps back on.
Well lets not be confused about anything...the 12psi springs are NO JOKE!!! They are strong! I removed the puny 7psi stock waste-gate springs, no problem. Then I went to grab the 12psi springs...what a noticeable difference. The original springs were soft and thin, maybe 1/16 of an inch thick coil and maybe the size of a red bull can of soda. The new springs were about the size of a normal soda can and about 1/8 of an inch thick coil. It took the help of my neighbor to fasten the waste-gate tops back on. I used all of my 6ft 2" and 200lbs of muscle to simply press the waste-gate caps up into place. My arm and shoulder are still shaking from the strain it required to hold the caps up and in place. But its done.
Should have enough miles by the weekend, but not sure if I will have the time to get it tuned for this weekend.
Old Nov 3, 2007 | 03:36 PM
  #164
rrmedicx's Avatar
rrmedicx
Just a few pics a took while breaking her in. I took her for a ride to the Beach and snapped a few shots.
Old Nov 4, 2007 | 08:28 AM
  #165
Jason333's Avatar
Jason333
hi
What shift **** is that?
Old Nov 4, 2007 | 02:22 PM
  #166
rrmedicx's Avatar
rrmedicx
Shift **** is a great investment...Got it from Forged Performance. Check with Sharif.
Got the miles I needed. Now I just have to follow up with my tuner in CT and schedule an appointment for a tune. At the very least I will be pushing 12 psi of boost thanks to the upgraded springs I just installed. Ultimately, I would like to have at least 3 maps...1 for 12psi, 14psi, and 16psi.
Old Nov 4, 2007 | 05:14 PM
  #167
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
That was Clint's (THX723) original design that he apparantly gave/sold to FP. I had it on my G and it was awesome!
Old Nov 17, 2007 | 07:14 PM
  #168
rrmedicx's Avatar
rrmedicx
The moment you all have been waiting for has arrived. Click here to see the results.
https://my350z.com/forum/showthread....97#post4699597
Old Dec 28, 2007 | 10:43 AM
  #169
rrmedicx's Avatar
rrmedicx
Yeah, update is I drove the 1000 miles to break it in, brought it to my tuner and had an unfortunate incident and blew the motor.
I shipped the motor back to Texas for inspection/tear down and rebuild.
Once I get it back, I will go back to my tuner and try again.
I will post up a link to the new thread once completed and with results.
Thanks for all of your support.
It has been a hell of a year for me. I am very much looking forward to 2008.
Old Jan 23, 2008 | 09:21 AM
  #170
ByThaBay's Avatar
ByThaBay
I would love to do videos of all this. I have a thread similar to this one on g35driver:
http://g35driver.com/forums/showthread.php?t=183421
but nothing nowhere near as complicated.
Old Jan 23, 2008 | 10:11 AM
  #171
rrmedicx's Avatar
rrmedicx
Upgrading from UTEC to ProEFI EMS and will post updates once everything is up and running and tuned. No need for unnecessary drama...Although this forum thrives on it. LOL
Old Jan 28, 2008 | 03:23 PM
  #172
rrmedicx's Avatar
rrmedicx
Just waiting for my new engine to get sent up from Texas. Unfortunately I am looking at Mid-Feb. '08. Once it arrives, I plan to run NA for about 750 miles.
Then I break things down again and install the Greddy Twins along with the ProEFI, in addition to oil cooling upgrades. Once I get things moving I will give you guys an update.
There will be a happy ending!
Old Jan 29, 2008 | 08:46 AM
  #173
rrmedicx's Avatar
rrmedicx
Thanks. Keep your eyes open. I might have the means to shoot a video for the install
Old Feb 10, 2008 | 05:55 PM
  #174
rrmedicx's Avatar
rrmedicx
New motor is being shipped Monday 2-11-08 to NYC from Texas. Should be here before the week is up.
Just need my new EMS to get here, but I won't need it for the break in 1000 miles as I will be running off of the stock ECU and stock injectors.
Old Feb 18, 2008 | 05:35 PM
  #175
rrmedicx's Avatar
rrmedicx
Well the new engine is in, along with the tranny, drivetrain and exhaust. All that is left is the top of the engine...plenum, injectors, fuel system components & intake. Shouldn't be more than a 1/2 days work and my Z will be alive once again. NA this time, but I haven't driven the car in sooo long. I can't wait.
Old Feb 18, 2008 | 06:47 PM
  #176
fklentz's Avatar
fklentz
I am very embarrassed to say...it was ugly. I spent enough money going back and forth to AutoZone buying tools which I will most likely only be using once...So I used a flathead screwdriver and found an angle that caught the inside of the bearing and worked it around with WD40 until it spun out just enough that I could barely catch an edge with a pair of pliers enough to yank it out. Very Crude but effective. Lets just say, the bearing that was in there is no longer recognizable.
Moving right along, the new bearing is in and looks great. Next I will attempt to install the flywheel and clutch. I just need to wait for my next day off Sunday.
I have a trick I use to remove the pilot bushing, I find a bolt that just fit's inside it, I then fill the pilot hole with grease, just start the bolt into the hole then tap it in with a light smack and usually it drives it right out.
Old Feb 19, 2008 | 04:23 AM
  #177
rrmedicx's Avatar
rrmedicx
Actually even easier is a 3/8" tap. I used it and had the pilot bushing out in a matter of 2 minutes.
Best option IMHO. Just FYI.
Old Feb 19, 2008 | 02:18 PM
  #178
Tomek350Z's Avatar
Tomek350Z
wow just read the thing....took me like a little over an hour...great write up though.....questions
..where did u learn to do all this yourself?
...what does the throttle body spacer exactly do...?
and the oil pan spacer is just so you can allow more oil for the turbos right? thanks
Old Feb 19, 2008 | 02:33 PM
  #179
rrmedicx's Avatar
rrmedicx
I learned by reading the service manual several times and from communicating with forum members here just as you are doing right now. You have to keep in mind, that if you are not putting together a stock car, the service manual is only useful to a certain point, then you have to ask for help. Example of this is if you are building a "built engine", with ARP head bolts. The stock service manual would advise of 65 ft lbs/torque for the heads and with ARP aftermarket studs, you can go as much as 93-95 ft lbs. torque. Of course if you only apply 65 ft lbs. of torque, you would be severely short changing yourself of the benefits of the head studs.
The throttle body spacer is an AAM product and it provides you with up to 3 additional ports to plug into for vacuum/boost lines. In case you need them for a fuel pressure regulator, or Boost gauge, or UTEC or whatever...
The oil pan spacer is to allow for oil return ports without having to drill into the engine upper oil pan. Thus allowing you to return the car to stock if you like without any major hassle...and the additional 1 quart of oil is added insurance.
Old Feb 24, 2008 | 02:02 PM
  #180
rrmedicx's Avatar
rrmedicx
Yeah, I'm 99% done on re-assembly. The only thing I am waiting for is a bolt to support the power steering pump. I stripped the original. That bolt should be there Monday for me. Once that goes in, I can complete the install, add fluids and start her up. The anticipation is killing me. But again it is only NA. I would love to dyno the car to get a before and after. I will speak with my tuner to see if that can be arranged. I don't expect high numbers with a low compression motor, but if anything it would make for a nice comparison shot.
