Another Oil Catch Can DIY - Pix
Old Mar 25, 2010 | 05:09 AM
  #41
RandomHer0's Avatar
RandomHer0
It is very accessible, I guess what I'm saying is if the valve failed. Which it doesn't seem like it would.
Old Mar 29, 2010 | 09:39 AM
  #42
thekinn's Avatar
thekinn
Bummer that the OP's pics are not visable any longer... But thanks to the others for keeping the thread alive. I ordered my catch can and will be installing soon.
Old Apr 2, 2010 | 06:46 PM
  #43
RAYZ33's Avatar
RAYZ33
Originally Posted by 06CPV35
Yes. Otherwise you'll get the brass fittings and 3/8" black hose if you don't.
Got mine a few days ago. Well made, looks nice, installing today.
-edit-
Installed:
-edit edit-
A little modification I did to mine:
Now my install 100% done. No copy-cats allowed
Cheers
I just ordered this catch can as well but would like to add the little guage you did to it before installing.
Care to share what you used and the procedure of it?? Preddy prease with a cherry on top?
Old Apr 3, 2010 | 06:12 AM
  #44
06CPV35's Avatar
06CPV35
^ Well since you included a cherry on top... ok why not
Drill holes with a 11/32" bit.
Tap hole with a 1/8-27 PPE tap.
*use cutting oil or just some engine oil during both those steps*
Fittings are 1/8th brass; thread x compression elbows.
Get brass ferule (sp?) inserts to go inside tube (look inside tube at connection in picture).
Get plastic compression collar rings. I didn't use the brass ones that came with fittings. I felt the brass rings that came with fittings might cut through soft vinyl tubing while tightening down compression nut.
Tube ID and OD I forget. Just take fitting and try with different sized tubes.
I got everything at a local OSH Hardware store.
Old Apr 3, 2010 | 08:24 AM
  #45
binder's Avatar
binder
They have those compression fittings and brass fittings at menards or lowes. I get my fittings from menards.
Old Apr 3, 2010 | 09:56 PM
  #46
RAYZ33's Avatar
RAYZ33
Woot thanks 06CPV35!! You also get chocolate sprinkles with it
So i take it there's no way of knowing where to measure and drill holes before mounting it with the PCV lines/ mounting bracket?
Old Apr 4, 2010 | 09:09 AM
  #47
06CPV35's Avatar
06CPV35
Chocolate sprinkels...awesome thanx
It's possible. The can slides and rotates in bracket where ever you want/need and has an allen set screw that'll hold the can in place. Mock it up in your engine bay, make your marks, remove bracket with can position set, start the sight tube mod.
G/L
Old Apr 4, 2010 | 09:23 AM
  #48
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
I luv you guys (zchickz can say this)!! I need one of these badly. Sweet!!
Old May 4, 2010 | 05:51 AM
  #49
thekinn's Avatar
thekinn
Stupid question.. I already installed this, so I didn't want to remove to test the drain valve at the bottom.
If the wing-nut at the bottom is farthest from the can - is this open or closed?
If I recall, I can to turn it clockwise for the nut to be farther away from the can (seems like tightening it). and logic would say that if I loosen in and the valve goes into the can, the oil will go through the hole in the screw and out the drain.
I'll probably need to at least partially remove this catch can to drain it - I just want to avoid some oil dripping into the engine bay.
Old May 4, 2010 | 07:04 AM
  #50
plumpzz's Avatar
plumpzz
Originally Posted by QuadCam
here's another type of one from Lingenfelter. It even has a drain at the bottom that you could somehow plumb back into the oil pan for passive drainback!
I have a similar style home depot special. I would NOT plumb that oil back into the oil pan. It smells heavy of fuel for some reason. It does not smell like the oil that comes out of my oil pan.
Old Oct 15, 2011 | 07:36 AM
  #51
MyKwikToys's Avatar
MyKwikToys
Ordered one, tks for the write up
Bill
Old Oct 16, 2011 | 06:14 AM
  #52
06CPV35's Avatar
06CPV35
^ You'll like. Mine still lokking and working like a champ.
Old Mar 26, 2012 | 06:42 AM
  #53
SullivanRacing's Avatar
SullivanRacing
i blocked off the pcv and where the emission tubes entered the intake manifold and ran the three tube from the valve covers down under the car.
these cars dont have blow by unless your tuner dosent know what he was doing...
Old Mar 26, 2012 | 07:47 AM
  #54
06CPV35's Avatar
06CPV35
Fine for racing. Illegal for street.
Many factory stock VQ's have blow-by, especially the revups (298/300hp stock VQ's). IMO, it's a design failure with the valvecover PCV internal baffle and these VQ's being vacuum monsters.
Old Dec 9, 2012 | 11:45 AM
  #55
blAk mAx's Avatar
blAk mAx
Just removed mine last night. Had a big oil leak coming from it. Bottom drain screw was loose and the gasket at the bottom was blown out. When it was installed one line was coming from the drivers side and the other was going to my intake tubeing right behind the pop charger. I'm assuming it was wrong since nothing led back to the pelenium
Old May 26, 2013 | 06:37 PM
  #56
dynasty21's Avatar
dynasty21
I know this is old, but why do we not connect the driver side valve cover?
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
