DIY VQ35HR Spark Plug Replacement
Old Apr 23, 2016 | 03:07 PM
HRMoneyPit's Avatar
HRMoneyPit
That seems weak for plugs too
But I did this job and didn't tq anything
Only things I tq are my lug nuts between sessions know track
Old Apr 23, 2016 | 03:26 PM
03s2kman's Avatar
03s2kman
Are these pictures reading a different measurement than ft-lbs?
Old Apr 23, 2016 | 03:28 PM
03s2kman's Avatar
03s2kman
sorry here is pic 2. I thought it the torque specs always read out like this N·m (kg-m,ft-lb)
Old Apr 23, 2016 | 07:57 PM
Italianjoe1's Avatar
Italianjoe1
The TB and small bolts like that are in in/lb, they aren't that tight. They only go into plastic manifolds, if you try to get them that tight you will break the bolts or pull the nut out of the manifold.
Old Sep 15, 2016 | 04:38 PM
zenki_z33's Avatar
zenki_z33
If I'm not mistaken the black wrench with white background is in/lbs, while white wrench with black background is ft/lbs.
350z82
Oct 1, 2015 06:25 PM
