Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Aug 14, 2012 | 08:18 PM
  #841
Brew_haha's Avatar
Brew_haha
Yea i got a GM stand alone and took less than a HR to make it plug and play and has the nice nylon loom for way less than what other companies charge
Old Aug 15, 2012 | 03:33 AM
  #842
Quamen's Avatar
Quamen
My point exactly. People are way over thinking the harness and making it hard on themselves. Forgot all the companies that say they can make a harness because not a single one has done it consistently.
Old Aug 18, 2012 | 05:21 AM
  #843
Cass007's Avatar
Cass007
Originally Posted by sidewaysracin
Well i just went to install my harness and it has the wrong coilpack plugs on it. So i had to wait over a month, got it late for the show, and now its the wrong oSo ne.. What the ****! This is retarded. So what else is gonna be wrong with the chasebays harness?
So Logan, you worked at chasebays and swore by their harness in your car. So why are you changing it now? I can understand changing the sikky mounts to fueled racing but whats the problem with the chasebays harness?
* cough cough * Hello... my car had the quickest turn time from swap to street, does things that nobody else can do (stock gauges), doesn't overheat in 90*F summer temps and harness is cutom built for my application.
Its not cheap... but like I said, my car is actually on the street.
Diebold Autosport - Franz Diebold - 540-808-2918
If you want your car to run, give him a call. Don't expect advice on your problem for free, he makes a living making race harnesses for some of the top rally teams in the world, so he gets paid for his time.
Old Aug 18, 2012 | 05:29 AM
  #844
CMyTailsBlink's Avatar
CMyTailsBlink
Just saw the last post and felt like making a post. My car still has all the stock gauges working, doesn't overheat in any temp, even really getting into it repeatedly, and doesn't have any crazy production harness. Bobby at CIN Motorsports used his knowledge and wired both the Nissan and Gm computers into the car. If you want something done right, that's who I'd recommend.
Check out my YouTube videos of the car. Just search for this same screen name.
Nick
Old Aug 18, 2012 | 09:47 AM
  #845
sidewaysracin's Avatar
sidewaysracin
So what has everyone done for the radiator and fans? Went to put in my stock stuff and they wont fit. You guys using slim line pushers ornwhat?
Old Aug 18, 2012 | 09:49 AM
  #846
CMyTailsBlink
Custom designed and built dual pass radiator from Fluidyne.
Old Aug 18, 2012 | 11:13 AM
  #847
Brew_haha's Avatar
Brew_haha
Mine took two months or less and most of the time was spent waiting on the motor to get built, trans to get built and shipped and the sikky kit to arrive.
Doesnt over heat with stock RAD still has AC. If you plan your swap it can be done in days its not rocket science.
CIN FTW Just mailed them some LSX swap parts for Bryan Settels car.
Sideways - you can use the stock rad and fans depending on the swap kit you are using you might have to do some cutting on the shroud. I used the sikky kit the first time around and had to cut a little. If you use the fueled kit then you wont have to cut any since it sits so far back.
For this 2nd time around since im going boosted I have changed to a 24x13x3 radiator with -16AN fittings and no filler neck. Its a dual pass so the cooling should be perfect and it sits right behind my intercooler perfectly. PRC hot rod did this for me for 329.99
Old Aug 18, 2012 | 01:03 PM
  #848
Quamen's Avatar
Quamen
I'm also running a 24x13x3 double pass made by Howe Racing. One 12" fan and I am good all day on temps with high compression.
Old Aug 18, 2012 | 09:06 PM
  #849
Royal_T's Avatar
Royal_T
^ what Fan did you get again
Old Aug 18, 2012 | 10:02 PM
  #850
Quamen's Avatar
Quamen
It is just a Mr. gasket fan. I think it was 2100cfm.
Old Aug 20, 2012 | 10:36 AM
  #851
Brew_haha's Avatar
Brew_haha
im using 2 8 inch CFR fans they are 1700 CFM a piece http://www.cfrperformance.com/Electr...ans_s/3628.htm
Old Aug 20, 2012 | 11:08 AM
  #852
Quamen's Avatar
Quamen
Just purchased a Meziere 40gpm electric water pump and all my nitrous components. Bottle is mounted and per-firewall is cut out. The car will be in beast mode early September... then for sale when I get into the 9's.
Old Aug 20, 2012 | 02:25 PM
  #853
2TH PWR's Avatar
2TH PWR
UGH my VQ is toasted. Not exactly sure what happened to it yet. So, looks like I will be coming up with a parts list soon for an LS then asking for a critique.
Old Aug 20, 2012 | 07:09 PM
  #854
Cass007's Avatar
Cass007
Mishimoto radiator, just because I already had it installed and Spal slimline fans. The sizes and part numbers are in my build thread.
Nick, seems there may be two shops that really know what they are doing then
Old Aug 23, 2012 | 02:25 PM
  #855
sidewaysracin
Originally Posted by bbs350z
the one i think your talking about might be the evap line. i completely eradicated my evap system. if you get rid of your evap canister out back and still have the stock gas tank itd be wise to cap off those ports where the evap canister connects.
You have any pics of what you did?
Old Aug 23, 2012 | 04:45 PM
  #856
Quamen's Avatar
Quamen
Posted pictures on my Facebook page of the pre-firewall cut out, the nitrous bottle mounted and the new electric water pump!
Old Aug 23, 2012 | 06:12 PM
  #857
2TH PWR's Avatar
2TH PWR
I don't expect to be spoonfed. But my time attack build is here.
https://my350z.com/forum/east-canada...onversion.html
I don't need Air Conditioning
I don't need VDC but I'd like ABS to keep me from flatspotting tires.
Otherwise I just need a bad *** motor/ trans combo that will allow my car to lay waste to everyone because roadracecar. Please help my Z demolish the competitions.
After reading a couple of nights this is what I am thinking I will need to buy so far.
modifications to the list if needed is appreciated.
-Fueled Racing Swap kit.
-Fueled Racing Clutch Hydraulics Kit?
- Aftermarket clutch and Flywheel?
-Fueled Racing Aluminum or Carbon Fibre drive shaft?
-Upgraded Radiator?
- Speedhut 4” Tach.
- custom exhaust
-LS2 T56 drop out. 2005 or 2006 GTO.
- Get GM VATS system disabled.
- Custom Harness?
- Walbro 255 fuel pump?
Old Aug 24, 2012 | 09:50 PM
  #858
Quamen's Avatar
Quamen
Painted engine bay with removed pre-firewall:
Nitrous/Fuel Solenoids:
Meziere WP119SHD electric water pump:
Nitrous bottle mounted:
Old Aug 24, 2012 | 09:55 PM
  #859
Quamen's Avatar
Quamen
Lexan windows:
Skinnies:
Satin black street wheels:
Old Aug 26, 2012 | 04:57 PM
  #860
Cass007's Avatar
Cass007
Looking good Quamen.
Does anyone know for sure if the AC compressor can be removed with the engine in the car? Does anyone have an AC compressor for an LS2 for sale?
