Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Aug 27, 2012 | 01:25 PM
  #861
Brew_haha's Avatar
Brew_haha
cass it can be removed. and you can buy my compressor PM or for faster email or text me logandbrewer@gmail.com or 205-365-0091. I can use my GM stock compressor location since the down pipe runs through there.
quamen ---good pict of the firewall removal. got any tips or tools list you used. what did you do with your brake lines and abs? making it all customs or what
Old Aug 27, 2012 | 01:27 PM
  #862
Brew_haha's Avatar
Brew_haha
Originally Posted by 2TH PWR
I don't expect to be spoonfed. But my time attack build is here.
https://my350z.com/forum/east-canada...onversion.html
I don't need Air Conditioning
I don't need VDC but I'd like ABS to keep me from flatspotting tires.
Otherwise I just need a bad *** motor/ trans combo that will allow my car to lay waste to everyone because roadracecar. Please help my Z demolish the competitions.
After reading a couple of nights this is what I am thinking I will need to buy so far.
modifications to the list if needed is appreciated.
-Fueled Racing Swap kit.
-Fueled Racing Clutch Hydraulics Kit?
- Aftermarket clutch and Flywheel?
-Fueled Racing Aluminum or Carbon Fibre drive shaft?
-Upgraded Radiator?
- Speedhut 4” Tach.
- custom exhaust
-LS2 T56 drop out. 2005 or 2006 GTO.
- Get GM VATS system disabled.
- Custom Harness?
- Walbro 255 fuel pump?
sounds about right. you don't really need a custom harness you can make the factory GM one work just fine
Old Aug 27, 2012 | 03:28 PM
  #863
Quamen's Avatar
Quamen
I used a sawzall and grinder. I removed the ABS last year and I am bending my own hard lines now. I machined the master cylinder so it is now a four port and the line lock solenoids mount directly to the master cylinder rather than being teed in.
Old Aug 27, 2012 | 08:39 PM
  #864
Quamen's Avatar
Quamen
Yes... this is going in a 350z!
Old Aug 28, 2012 | 07:01 AM
  #865
2TH PWR's Avatar
2TH PWR
Thanks, the wiring is what I am the most intimidated by at this point.
Old Aug 28, 2012 | 05:30 PM
  #866
04.350z's Avatar
04.350z
-Upgraded Radiator?
- Speedhut 4” Tach.
- custom exhaust
- Custom Harness?
most of us have 10k+ into our swaps .
i sold my vq and trans and turbo kit and still have put 8k into this swap.
not counting the rebuild.
Old Aug 29, 2012 | 04:11 PM
  #867
sidewaysracin's Avatar
sidewaysracin
I dont think that intake mani is gonna fit under the stock hood. Thats a nice manifold for the price though.
Old Aug 29, 2012 | 05:30 PM
  #868
2TH PWR's Avatar
2TH PWR
Thanks man.
Honestly. It's not the cost. I think it's a good $ to performance ratio. It's my lack of wrench turning experience that has me spooked about it. Still working on it.
Old Aug 29, 2012 | 07:23 PM
  #869
Quamen's Avatar
Quamen
The throttle body is the only portion that doesn't fit actually. Either way I don't really care.
Old Aug 30, 2012 | 09:23 AM
  #870
Brew_haha's Avatar
Brew_haha
Thanks man.
Fly me out to CA and ill do the swap for you or have it shipped to the states.
Old Aug 30, 2012 | 09:45 AM
  #871
2TH PWR's Avatar
2TH PWR
LOL thanks man. At that point I might become cost conscious. And I'm not in sunny California, I'm in Canada. And it's nice now, maybe 85 and sunny. But in a couple of months it will be 25 degrees and snowy.
Í have to admit. I'm too scared to do this right now. I just want to finish my track season. I''m in first place and clinch the "national title"" with one more 4th place finish. Im going to drop in a $600 motor with my friends to get rolling and gain some confidence and tackle this swap after.
Old Aug 30, 2012 | 12:31 PM
  #872
Brew_haha's Avatar
Brew_haha
I know where you are located lol i love the cold alot more than the heat
Old Aug 30, 2012 | 07:47 PM
  #873
Quamen's Avatar
Quamen
My V8 sits further back than your V6!
Old Aug 30, 2012 | 08:45 PM
  #874
Brew_haha's Avatar
Brew_haha
After Quamens shiny new painted bay my mock up pics look boring.
mocked up snyperz's turbo kit tonight
Going to have to make a new passenger side mount to clear the massive 4 inch downpipe but it all fits on a Gsedan just as it did on the 350z
Have to get a different thermostat and water neck and come straight out instead of like factory.
Old Aug 31, 2012 | 12:18 AM
  #875
Quamen's Avatar
Quamen
Very nice Logan! Why dont you cut and weld the thermostat?
Old Aug 31, 2012 | 03:46 AM
  #876
04.350z's Avatar
04.350z
I bough a 360 degree water neck with colder thermostat it was like 100 bucks
Old Aug 31, 2012 | 12:24 PM
  #877
WeightLimit's Avatar
WeightLimit
Marked for later
Old Aug 31, 2012 | 12:41 PM
  #878
Brew_haha's Avatar
Brew_haha
It was a brand new one from jegs that was welded but with a little searching i found this from the same guys i got my alternator and powersteering bracket from. they do alot of sand rails.
Here is the difference in motor location between in the sikky kit and the fueled racing kit if anyone wants to know. Bryan settle was asking me a bunch of questions about the kit since they have no pictures.
Sikky kit placement
Fueled racing kit - sits alot further back
Old Aug 31, 2012 | 12:52 PM
  #879
Quamen's Avatar
Quamen
Nice! Looks like someone other than me had the ***** to sove the motor all the way back. The transmission is a pain to get at but it is well worth it!
Old Aug 31, 2012 | 01:25 PM
  #880
Brew_haha's Avatar
Brew_haha
Well luckily i never had to try and drop the trans with the sikky kit but its so simple to pull the motor and trans out at once its not even worth the time or effort to try to take the trans out with out the motor. IV gotten the motor down and out in 45min disconnecting the front end and everything.
