Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Oct 9, 2012 | 04:47 PM
  #981
sidewaysracin's Avatar
sidewaysracin
Come on, no one needs an exhaust and y pipe?
Old Oct 11, 2012 | 09:56 AM
  #982
endless_summers's Avatar
endless_summers
Originally Posted by Brew_haha
Wiring in a stand alone harness isn't hard
THIS. And Chase bays wiring harnesses seem underwired. I have been working on a s14 240sx ls1/t56 swap for the last couple months. Chasebays harness with every plug connected with key on caused the ground wire on the backside of the head and the coil pack harnesses and coil packs themself get extremely hot to the touch. Engine would turn over but never started. Harness was removed, sent back to Chasebays for diagnosis and returned to us because Chasebays could find nothing wrong. We ordered a standalone wire harness from a different company, wired it in by ourselves to the 240sx chassis and it fired right up and idled great. No wires get hot anymore and the engine runs. Chasebays seems to either use too small gauge wire for everything or run too many sensors off of one single wire. Also, Chasebays has no fuses or relays in their harness. This new harness did. If Chasebays used a fuseblock, it should blow the fuse before the wires overheat.
Just my experience. Take it as you wish.
Plus, chasebays has a no return policy once the harness is shipped. $600 sitting in a box in the garage now. Can't sell it to anyone else because it doesn't work. Well, wouldn't be able to sell it to anyone else and be able to sleep at night knowing that it doesn't work.
Old Oct 11, 2012 | 02:50 PM
  #983
sidewaysracin
Well i had some of the same probelms but ive been fixing them as i find them. Most recently i figured out the crank sensor was wired backwards too. So at least when im done ill be able to to do anything with a wiring harness. Lol i did talk to chase at chasebays and he helped out a bit.
As for the sikky shifter im still having issues. So im just done for this year since its gonna snow soon. On to the turbo setup! I need to sell the sikky long tubes and the exhaust i had made a few weeks ago. Please snd out the word to anyone doing a swap. Once that stuff is gone i can bring the car to the shop to start the turbo manis and piping. PLEASE HELP!
Old Oct 16, 2012 | 12:16 PM
  #984
Cass007's Avatar
Cass007
Sorry for that... tried to tell you it may cause you drama.
Old Oct 16, 2012 | 02:45 PM
  #985
mhammel20's Avatar
mhammel20
So after reading all these problems with a wiring harness... should i just stick to sikky? Ill be taking my block, heads, rods, cam etc in to the machine shop/race shop to have the machine work done and the engine put together. Gotta wait on pistons til after They hone the walls
Old Oct 16, 2012 | 03:10 PM
  #986
Quamen's Avatar
Quamen
You should do it yourself (100% serious on this post)
Old Oct 16, 2012 | 03:57 PM
  #987
sh0rtys463's Avatar
sh0rtys463
Wish I would have done this ^^ instead of dealing with Chasebays. Time for first startup so we'll see how much they did wrong with my harness too! It's unfortunate that a select few were really hyping up chasebays a few months back and now everyone is saying stay away from them.
Old Oct 16, 2012 | 04:31 PM
  #988
mhammel20's Avatar
mhammel20
i would but my weakness is wiring lol. plus im runnign everything else, not wanting to wire it like a drag car. if sikkys works then why not use theres.
Old Oct 16, 2012 | 04:35 PM
  #989
QTB's Avatar
QTB
Keep in mind I have not started mine but I used speed scene wiring. Great support and you send in the pcm, gas pedal, and tb and they make sure it works before they send it back.
Old Oct 16, 2012 | 05:52 PM
  #990
mhammel20's Avatar
mhammel20
i am going to get with you on info about them.. ill pm you
Old Oct 17, 2012 | 04:28 AM
  #991
Brew_haha's Avatar
Brew_haha
Endless summer do a charge back dude. You can do it with your bank or CC company. Don't be screwed over by a small company. If your product doesn't work like it said it would and you have returned it for nothing to be done to it then its not your fault and they will help. Isn't the first time IV seen customers do it or even go to the lengths of tryin to sue to get their money back. You could always call the BBB see what they say to due
Old Oct 17, 2012 | 08:29 AM
  #992
Royal_T's Avatar
Royal_T
I will let everyone know how my harness goes, but I did without a lot of things so fingers crosses, and if it does not work.. We will just make our own, problem solved.
Old Oct 17, 2012 | 11:45 AM
  #993
sidewaysracin
Chasebays gave me a store credit for all the **** i had to fix myself
Old Oct 18, 2012 | 12:35 AM
  #994
ducky's Avatar
ducky
With the wiring harness, there are other companies that have a good product...we have seen diebold autosport, currentperforamance and even speedscene wiring. I was going to go with currentperforamance but went with PSIconversion. They as well have a good product as it seems but the proof is in the pudding once it is all systems go.
Turnaround time is quick. I ordered on Saturday, shipped out on Monday and here yesterday. Given they have it instock and any needed modifications they will do pretty much the same or next day as in my case.
Plus they worked with me on the weekend, I left a message Friday night and they gave me a call back on Saturday to discuss my build.
NOW I am posting this cause if any company handles their business like this then they are in it to win it.
It has a DLC connector and all the underwire for the dash/gauge hookups. I am going to attempt to use the stock tach and figure it out' if it becomes too much a headache then I will use a speedhut tach.
Old Oct 18, 2012 | 07:22 AM
  #995
Brew_haha's Avatar
Brew_haha
PSI for the win and edafe call chase bays they have their stuff corrected now with the inj/coils on separate fuses now might want to go ahead and send yours back and let them fix it other wise with all of the powers combined like they have yours setup now you will just keep blowing your main fuse do to it drawing over 40 amps email Kevin@chasebays.com
Old Oct 18, 2012 | 10:26 PM
  #996
ducky's Avatar
ducky
After having my fueled racing kit since since spring I finally went to mock it up myself . Alas, I'm sure they sent me the wrong one...they probably sent me a s chassis kit. gonna give them a call on Monday.Funny I just now noticed it....
Old Oct 19, 2012 | 06:33 AM
  #997
ducky's Avatar
ducky
well just got with Logan who also has the FR kit this is how it's made so the way I had it mounted was right...nothing against FR but ill end up modding the mount for my liking
Just got off the phone with Todd at FR and all is good now, just needed a pic to be sure of mounting point(confusion on my end). I am going back to the shop on Monday to refit, also since I have a 4L80e there is no mount available for it from FR. Todd advised me to mock it up with the standard tranny mount that comes with the kit and make a template with the 4L80e and he will me make a new one for free and have it available with their kits going forward. AWE-some!!! to FR
Old Oct 19, 2012 | 09:47 AM
  #998
ducky's Avatar
ducky
pics of the FR oil pan made by Moroso;
Jake brought me something as well...
Old Oct 21, 2012 | 07:49 AM
  #999
04.350z's Avatar
04.350z
you say it has a DLC? can you post pictures of it and how its pin'd in the ecm? i want to wire one into mine but couldnt find any info on how to wire it.
Old Oct 21, 2012 | 07:56 AM
  #1000
endless_summers
We used the same harness on my buddy's s14 and it fired up first crank and idles great! Instructions were great and anytime we called, we got a phone call back shortly. Even after hours. Great customer support!
