Engine Swaps For all your engine swap experiences, ideas, questions, & more..
Good things to mod/replace while swapping VQs
Old Dec 19, 2019 | 08:36 PM
Supermotogoon's Avatar
Supermotogoon
Default Good things to mod/replace while swapping VQs
Hey guys! Been reading for years but this is my first post. So I have a rod knock, jdm vq on the way. What are some things I should replace before iy goes in? At least putting some headers on. Newer oil pump? (Its a 2003) pathfinder coolant mod? Haven't researched that yet...anything else?
Old Dec 19, 2019 | 08:54 PM
rustyschopshop's Avatar
rustyschopshop
bare minimum would do a rear main seal, also would consider replacing the clutch especially if much older.
Old Dec 19, 2019 | 08:56 PM
Supermotogoon
Thanks man, I have a pretty fresh stage 3 but I am debating a new clutch
Old Dec 19, 2019 | 09:27 PM
bealljk's Avatar
bealljk
fresh rebuild?
where did you get your block?
What internals do you have inside?
Are you going NA / Turbo / Supercharge?
What do you want out of the car?
What are you going to do with the car after the build?
I would swap transmission fluid / rear diff fluid
belts / hoses / oil / filter / coolant / plugs / camshaft & crank shaft sensors
Clutch / throwout bearing / steel-braided clutch line
I would research other people's build that you want to 'get to' and read their build threads and see what they did...see what worked, see what didnt.
Old Dec 19, 2019 | 11:02 PM
813_350Z's Avatar
813_350Z
Originally Posted by bealljk
fresh rebuild?
Don't forget motor mounts while you are in there. Much easier doing it now while the engine is out.
Old Dec 21, 2019 | 01:39 AM
Supermotogoon
I wont be doing more then a few bolt ons. Just a fun commuter really. Reliability is most important. I ordered a jdm motor so something with under 65k.
Old Jan 28, 2020 | 01:10 PM
DeusExMaxima's Avatar
DeusExMaxima
What did you end up swapping or improving?
Old Feb 3, 2020 | 10:54 AM
Supermotogoon
Lets see... solid motor mounts, poly tranny mount, oem throwout bearing/sleeve. The cast version of the shift fork (03s had flimsy stamped steel), steel clutch line, silicone hoses, spark plugs, fluids and I think thats it
Old Feb 3, 2020 | 10:57 AM
Supermotogoon
The actual motor and all accesories was from a jdm car with 50k..actually finally got the motor/tranny out last night
Old Feb 3, 2020 | 08:15 PM
813_350Z's Avatar
813_350Z
If you have not already ordered them, just stick with poly motor mounts since you have a daily. Less NVH. I wouldn't get solid unless you're making ALOT of power.
Old Feb 9, 2020 | 11:25 AM
Supermotogoon
To late already installed lol
aireq
Feb 20, 2019 04:42 AM
jusdaveman
Feb 6, 2016 04:34 PM
blackmamba89
Oct 24, 2013 01:35 PM
Jissan
Aug 30, 2013 05:58 AM
chriswagner92
Sep 5, 2012 07:03 PM
