FS: Vq35de sleeved and bored block 3.8L
Old 07-02-2019, 03:49 AM
Lifessimple
Lifessimple's Avatar
Default Vq35de sleeved and bored block 3.8L
Selling my sleeved and bored block and pistons. 1,500 miles before I through my rod bearings, no damages to rods or motor, more pics can be posted as requested. I have everything listed below this post for sale for a DE so lmk what you need and I most likely have it! I'm from IL, shipping is possible but may be expensive. Details are below.
Darton wet sleeves 100mm
100mm Arias 9:1 pistons
Eagle H beam rods with ARP studs
asking 2,500$ obo, sold car a while back !
Lifessimple is offline
Old 07-03-2019, 02:37 AM
Lifessimple
Bump!!
I have heads with BC titanium valve springs and retainers too and all engine parts for a de, just lmk what u need and I most likely have it.
Old 07-05-2019, 05:55 PM
DLCLAUSON
DLCLAUSON's Avatar
Do cams come with the heads ? Are the valves stock or ?
DLCLAUSON is offline
Old 07-06-2019, 03:30 AM
Lifessimple
Yes I can can include the cams, cams and valves are stock, only upgrades springs and retainers and ferrea seals.
Old 07-06-2019, 05:41 AM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
Since OP is updating this ad with heads for a longblock sale, please add a new price for the longblock sale. Verification photos should be added as well.
dkmura is offline
Old 07-06-2019, 08:28 AM
Lifessimple
Performance internals are all forged rods and oversized pistons arias brand with a darton sleeved block.
I have everything for this engine to run unless sold below!
03 OEM Tail lights
$ 100
OEM camshafts (137k miles)
$100
OEM camashaft caps
$50
Cylinder heads with Ferrea valve stem seals and Brian Crower titanium valve springs and retainers. Heads have 137k miles, springs and retainers have 1,500 miles.
$600
OEM front and rear timing covers
80$
Darton Sleeved 100mm block with 100mm Arias 9:1 compression pistons and eagle H beam rods bored to a 3.8L block.
$2,500
OEM fuel rail
$50
OEM starter
$20
OEM VVT solenoids
$50
Valve covers
$50
Ignitions coils
$120
Camshaft exhaust and intake sprockets/gears
$ 100
Water pump
$20
Rev up oil pump
$160
ARP main studs
SOLD
ARP head studs
SOLD
Intake plenum upper and lower
$250
Upper oil pan
$ SOLD
6 puck Z1 motorsports Clutch
$ SOLD
Uprev GT MAF
$ SOLD
Turbonetics single turbo kit
$ SOLD
DC headers
$ SOLD
I have EVERYTHING for this motor for it to be running except rod bearings so lmk what you need, the list above is just the main parts.
Feel free to ask anything !
Old 07-06-2019, 12:15 PM
Lifessimple
ARP main and Head studs sold!
BUMP!
Old 07-06-2019, 04:22 PM
DLCLAUSON
DLCLAUSON's Avatar
I thought if the cams were other than stock I would be interested in them but not if they are stock . Has there been any work done to the heads ,ie ported and or ? How many miles ? what is your price ?
Old 07-06-2019, 04:28 PM
DLCLAUSON
DLCLAUSON's Avatar
Don't sell the cam bearing caps , they need to stay with the heads !!! Do you take PayPal ?
Old 07-06-2019, 05:34 PM
Lifessimple
Nope just stock cams, heads were just cleaned, resurfaced and OEM valves were relapped and installed new Ferrea valve stems and Brian Crower valve springs and retainers. Asking $600 for both heads if your local otherwise I'd have to get an estimate for shipping.
Yes I take PayPal and I have the OEM caps still so no worries!
Old 07-09-2019, 12:46 AM
Lifessimple
Bump! Remember guys I have other things for this motor and all the little etc. Bits and pieces laying around, I need everything gone so I'm flexible on all pricing dont hesitate to ask.
Old 07-09-2019, 05:14 PM
OldManZ350
OldManZ350's Avatar
Just wondering, Why did you MAX out the Bore on the Cylinders @ 100mm's?
Now if you scuff a cyl wall it will need to be resleeved.
OldManZ350 is offline
Old 07-10-2019, 02:32 AM
Lifessimple
Hello! That's a true statement, however at the event and rate and what I was going through, that was the only option I had, it was a lot of miscommunications with the machine shop and i had already ordered pistons to fit so in the end, I was stuck with 100mm's. So at that point of it being too late. It was go big or go home, I had intentions of making big power, made 447whp @15 psi, then realized the single turbo set up and my injectors were limiting me, etc. Etc. Etc. Pretty much I dumped a lot of money , too much money to turn back, and I spun a bearing which luckily was the only thing that got damaged, and although it's a cheap fix, the money I've invested prior to this was enough to the point where I should just stop, therefore I sold the car, now I'm engaged and I got myself a Lexus GS350 😬 (just stuck which a bunch of old Z parts now)
OldManZ350 (07-10-2019)
Old 07-15-2019, 03:58 AM
Lifessimple
Bump!!! I'll be real lenient with prices guys, just need these gone because they've been sitting here.
Old 07-15-2019, 06:58 AM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Take this the right way -
I've never seen a sleeved block work out long term and when the flour hits the fan fixing/repairing the sleeve and piston is beyond the benefit of the cost. So you take a big risk with an expensive buy-in, a (relatively) high probability of failure, and a high cost to remedy for 3/10th of a liter additional engine displacement.
the VQ world has changed quite a bit and anyone with funds aren't putting them into a 350z / 370z, hell - even the GTR is becoming mainstream.
If I were you - I'd plan on literally (or figurately) giving it away or having one-hell of a coffee table
with that being said good luck with the sale - I truly hope you find a good home for it
(and now let me talk out of the other side of my mouth) - I've been keeping an eye on it and I may be interested if it doesn't sell and you want to throw me the insane deal on it!
and free bump … get some convo started on this
bealljk is offline
Old 07-15-2019, 08:19 AM
Lifessimple
I appreciate and always am open to opinions, open door policy. Like I said, it's been sitting here and I no longer have a Z. Throw me a deal and PM me and I can get this shipped today, tomorrow, whenever. Need additional pics lmk, I'm working right now and its staring at me so I can take any pics u need from it right now.
The following 2 users liked this post by Lifessimple:
bealljk (07-15-2019), djnekkon (08-06-2019)
Old 07-29-2019, 03:46 PM
Lifessimple
Bump guys, open to any prices. Price we agree on Includes shipping
Old 08-05-2019, 05:29 AM
Lifessimple
Block, pistons, rods, main caps SOLD
bealljk (08-05-2019), OldManZ350 (08-05-2019)
Old 08-05-2019, 06:56 AM
bealljk
bealljk's Avatar
congrats LS - happy it worked out!
bealljk is offline
Old 08-05-2019, 08:03 AM
Lifessimple
Thanks man! Got some little things left here and there, just lmk what you need if anything.
Timing gears and chains and pump are pending sale.
specialist
06-26-2013 10:14 PM
Yancy
05-11-2008 06:08 PM
sentry65
07-26-2006 10:58 PM
Quick Reply: FS: Vq35de sleeved and bored block 3.8L
