I think i twisted my chassy
Old Oct 22, 2005 | 01:22 PM
Fairlady_z33's Avatar
Fairlady_z33
Default I think i twisted my chassy
Today i jacked up my car but i jacked it by one side both ends front ansd back at the same time. The front was slightly a little higher. I started looking at the test pipes but i look and said to my self let me pay some one. So when I lower the jack and take it off i look at my car and the tire is not at the same distance from the fender as it use to be, it looked a little high. I went to the other side and looked at it and noticed their was a difference on both sides about a 1/2 inch of difference. So I tell my self good F****** job you just F***** up your car. So i start it up and take it for a long drive so see if maybe it would fix i take some speed bumps and holes and all that and when i get home it looks like ti got fixed but not sure my drive way is a little crooked so i will have to put it on a plain street. Has this happen to anyone. Can this be fixed. Please help Im thinking about taking it into nissan and see what they tell me.
Old Oct 22, 2005 | 01:55 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Independent suspension.
Old Oct 22, 2005 | 02:07 PM
jmcmorante's Avatar
jmcmorante
WOW. So is there a way to ge tit back. Im interested!
Old Oct 22, 2005 | 02:23 PM
drumma022's Avatar
drumma022
Usually a simple forward, stop, reverse, stop with abrupt stops will settle the suspension back to normal.
Old Oct 22, 2005 | 02:24 PM
Fairlady_z33
ok thanks
Old Oct 22, 2005 | 04:01 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
wow
Old Oct 22, 2005 | 04:59 PM
TiPIACE's Avatar
TiPIACE
the doors are best way to tell if youve bent the chassis
if they open and close as they use to, and dont snag the lock pin then you're fine
Old Oct 22, 2005 | 05:16 PM
SnakeBitten's Avatar
SnakeBitten
If thats all it took to twist a Z's chassis it would be sad.
Old Oct 23, 2005 | 06:37 AM
350xfire's Avatar
350xfire
Whe you jacked up the car, the shocks and springs were extended, causing the slight increase in height. Like said before, drive the car. It will settle back down.
Old Oct 23, 2005 | 06:46 PM
Fairlady_z33
Yea i think it got back to normal i hope becouse if not it will be a pain in the a** to get it back to factory or close to it. The thing is that the front staid normal but the back was the one that was off
Old Oct 23, 2005 | 07:37 PM
illZ's Avatar
illZ
Originally Posted by Z1 Performance
wow
+1
Old Oct 23, 2005 | 07:53 PM
ares's Avatar
ares
Veteran
heh; the frame is way stronger than that. otherwise every time you went up on a curb or something the frame would bend.
Old Oct 23, 2005 | 11:02 PM
G352NV's Avatar
G352NV
lol, just take it out of gear and let down the ebrake.
Old Oct 24, 2005 | 04:51 AM
Mike Wazowski's Avatar
Mike Wazowski
Here is what I did to my Z and the Chassis never got hurt one bit.
Attached Thumbnails I think i twisted my chassy-drive-front.jpg   I think i twisted my chassy-drive-rear.jpg   I think i twisted my chassy-driver-front-1.jpg   I think i twisted my chassy-pass-side-front-2.jpg   I think i twisted my chassy-side-front-view.jpg
Old Oct 24, 2005 | 11:13 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Seeing that makes me wanna cry...
Old Oct 24, 2005 | 02:17 PM
barthelb's Avatar
barthelb
Master
Geez what did you do, a 360"
Old Oct 24, 2005 | 04:21 PM
EdgeOfSanity's Avatar
EdgeOfSanity
this is the funniest thread i've read in awhile here.
Old Oct 25, 2005 | 05:02 AM
Mike Wazowski
Hydroplaned after being cut off by a truck, slammed a wall front and then spun around and hit it in the back. ****ing $14,000.00 later it is better than new.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
cashmoney03
Sep 27, 2015 05:24 PM
hardkicks
Sep 20, 2015 12:28 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
