Lighting Project (Retroed Projectors+...)
Old Nov 15, 2005 | 04:32 AM
PeteNJ's Avatar
PeteNJ
Default Lighting Project (Retroed Projectors+...)
I know it is not a Z, but I thought you guys would get a kick out of my project.
Details on the project:
Retrofitted Stanley Low beam projectors (TSX/Color modded)
4300K Osram D2S Bulbs
12" CCFL lamps in clearance strips
Custom Amber LED clear corners
Daytime shot:
Closeup on headlight:
Parking lights on at dusk:
Parking lights in artificial lighting:
Everything on:
Closeup wall shot:
50ft wall shot with color at cutoff:
Bling effect of color at cutoff:
Front output shot:
Width shot:
Old Nov 15, 2005 | 04:33 AM
PeteNJ's Avatar
PeteNJ
Sidewall shot:
There you have it!
Old Nov 15, 2005 | 05:13 AM
MJBsZ's Avatar
MJBsZ
Looks really nice, how long did it take you and what modifications were necessary? Also, is that just your low beems on in the "width" and "front output" shot?
Old Nov 15, 2005 | 05:37 AM
mandm177's Avatar
mandm177
really really impressive...im gonna start on my retrofit project in a month or so...im planning to use s2k projectors and put them in a Z, and tips?
also, how did you make your strip light up so evenly? doesnt look like you used led's at all...
Old Nov 15, 2005 | 06:50 AM
PeteNJ's Avatar
PeteNJ
Took me about a month working on the headlights on weekends (50+ hrs of labor in total). Low beam only in all shots. The highbeam is still the stock halogen H4.
Old Nov 15, 2005 | 06:59 AM
PeteNJ's Avatar
PeteNJ
S2K Projectors are made by the same company that produces TSX/TL units (Stanley). They are probably one of the best single xenon projectors available and I would have gone with them if they were a tad cheaper. The output is super wide and bright! My only advice is to take your time. If you are going to do this projext and invest all this time. Do it right. This means buying an extra set of headlights while you work on your own.
The strip is lit up via CCFL not LED. I have a custom LED circuit in my clear corners. Here is some info on CCFL:
CCFL Lamp
Cold cathode fluorescent Lamp (CCFL) belongs to gas discharge lamp. In the electric field, radiant energy makes phosphor lighting.
Inside the phosphor coated glass tube, there are rare gases and a slight amount of mercury. By the reason of high electric field between two ends, a few electrons will hit electrodes. Then more and more electrons come out, as a result of this, gas discharge occurs. Mercury atoms will emit 253.7 nm ultraviolet rays.
Features (CCFL)
High brightness, High-Efficiency, Low power consumption and long life.
Excellent vibration and impact resistance.
Durable and excellent blinking characteristics.
Quick start at low temperature.
Small size and light weight.
Low heating.
Applications (CCFL)
Backlighting for LCD.
Light sources for Scanner.
Various types of displays and decorating lights
Old Nov 15, 2005 | 07:34 AM
mandm177's Avatar
mandm177
i actually had the idea of a CCFL for the headlight strip, but i was wondering how you got it to go along with the curve of the light...and was there enough room between the reflector and the base of the housing itself, or did you just cut out a slot for it? you also had to wire in a resistor for the ccfl, right? if you dont mind me asking, where did you get it?
i already do have an extra set of lights, and my friend is selling my his s2k projectors for a really good price, so i cant go wrong there...i did a black housing project a while back, and painted my reflectors black also, and hte light output sucked...hence the projector project!
Old Nov 15, 2005 | 07:49 AM
PeteNJ's Avatar
PeteNJ
I had to cut up part of the clearance strip lens to make the CCFL tube fit. The reflector portion of the strip is flat so the light sits there. I would recommend buying a bunch of tubes because they are very easy to break. I got them here: www.svc.com $5 a pop.
They are very simple to wire just splice into the +/- leads. It comes with a 12V inverter.
Old Nov 15, 2005 | 08:13 AM
THE TECH's Avatar
THE TECH
Looks very nice!
Old Nov 15, 2005 | 08:43 AM
JDMFairlady21's Avatar
JDMFairlady21
damn anytime you wanna do that for my Z, let me know!
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
