Vertical Doors?
Old Dec 8, 2005 | 01:48 PM
will350z's Avatar
will350z
Default Vertical Doors?
I know there are tons of vertical door kits out there, it's like everyone and their mom has a kit, but which ones are reputable?
I've heard GT Factory is the way to go, but that there is a "clearance" issue with the Z doors for all the kits...
Old Dec 8, 2005 | 03:08 PM
bamyi's Avatar
bamyi
either do a search or look for threads in the modification sections. There's tons of threads on this. Good luck and enjoy your modding.
Old Dec 8, 2005 | 03:40 PM
Escobar's Avatar
Escobar
+1 ^ you can find tons of stuff from previous threads.
Old Dec 8, 2005 | 03:45 PM
abyss's Avatar
abyss
If its a show car get the Verticle Door kit, if its daily driven get the LSD door kit.
Old Dec 8, 2005 | 05:42 PM
will350z's Avatar
will350z
As for now, it's a daily driver, but it's going to be turned into a full on project/show car... In the mean time, I guess I should search through the sea of threads and find what im looking for, thanks for the help/suggestions.
Old Dec 8, 2005 | 05:46 PM
ClaytonC01's Avatar
ClaytonC01
+1 on the search, there were alot of posts about this
Old Dec 8, 2005 | 05:59 PM
kcobean's Avatar
kcobean
here's the scoop on doors....The VDI hinges are great. They bolt on (minus some cutting or rolling of the inside of the fender which ALL kits will require), and don't seem to have alot of sagging or misalignment issues when properly installed. They open up about 30 degrees horizontal so you can get in and out of the car without lifting the door if you want. The downside of these is that the door can be lifted prior to the interior door panel clearing the a-pillar, so if people don't know how to open the doors (out first, then up), they will f' up the inside door panels of your car. It's a pain in the *** and it's almost inevitable with both the VDI and LSD kits.
The GT Factory kit is a whole different animal. It requires frame cutting and welding to install and is absolutely not reversible. The doors open about 4 or 5 inches and then they must be lifted vertically. They open true 90 degrees and are very cool looking, but you cannot get into or out of the car without lifting them because the door doesn't open out hardly at all. This kit requires replacing the interior door panel with a fiberglass or carbon fiber door panel with a slimmer vent bulge so that the door panel will clear the a-pillar without the outward swing that the VDI/LSD kits require.
I have the VDI kit and I love the way it looks, fits and closes. The LSD kit is very similar, though I can't speak to its' quality. It will run you anywhere from $1200 to $1800 depending on where you buy, and install will take no less than 8 hours.
The GT factory door kit is something like 1K for the hinges and 4 or 5 hundred for the door panels. Install will be in the thousands unless you find a good deal because that install is a major PITA.
Hope this helps!
there are pictures of my car with the VDI kit at the gallery link in my sig. check it out.
juliosuburban's Avatar
juliosuburban
I've installed many of the vertical door kits and they're quality after about a year is bad. Half came back with pumps broken and hinges rusting. GT Factory, I would recommend over the bolt on's. Very strong kit.
Old Dec 8, 2005 | 06:29 PM
kcobean's Avatar
kcobean
What pumps are you speaking of? Do you mean the struts?
Old Dec 9, 2005 | 05:51 PM
MeetJoeAsian's Avatar
MeetJoeAsian
is there actually a real way of getting lamborghini doors? ones that do not open out and the swivel up? I want one that closes and opens vertically just like real lamborghini...anyone know of anybody who can do that? I had a chance to drive diablo and a murcielago once, and those doors are badass
Old Dec 9, 2005 | 06:19 PM
kcobean's Avatar
kcobean
It will never happen on the Z because the door sits inside the frame of the car, therefore it must swing out a little to get the door clear of the A-pillar. Note the angle of the window on the Lambos...that angle puts the actual door clear of the roof and a-pillar.
The GT Factory doors are as close as you're going to get. Those open outward just barely before going fully vertical.
Old Dec 10, 2005 | 06:11 AM
PumpedVA's Avatar
PumpedVA
Somebody say GT factory?
Old Dec 10, 2005 | 06:57 AM
kcobean's Avatar
kcobean
And here's a better picture that shows a comparison of how far each of the door kits open.
Old Dec 10, 2005 | 01:48 PM
PumpedVA's Avatar
PumpedVA
I keep seeing on thing about my car I am having problems with I need some 20" wheels look small
Old Feb 16, 2006 | 11:28 AM
kapoosh1's Avatar
kapoosh1
anyone heard of the Extreme Dimensions Vertical door kit?? is it any good?
Old Mar 2, 2006 | 12:46 PM
DeZi_chokro's Avatar
DeZi_chokro
what about this site? http://www.lsd-doors.com/indexlsd.html
they make any good products?? i saw one of these while i was watching "mtv's pimp my ride" show. it looks cool!
Mikey R6
Sep 19, 2015 01:48 AM
roadmax
Sep 12, 2015 05:55 PM
AP350z223
Sep 8, 2015 04:38 PM
