Autotecknic or Craft Square?
Old May 16, 2006 | 07:49 AM
  #161
gringott's Avatar
gringott
I posted a simple how to on how to tighten the ball joint on the mirror. It actually is a very simple thing, just use the allen key they gave you. Here is the link.
https://my350z.com/forum/exterior-and-interior/191118-autotechnic-cf-mirrors-loose-pivot-point.html
And unless you actually have a defective mirror or part, there is no reason to modify anything or use glue, etc. Properly set up the mirror should work like any other. Just understand the principals involved - the lenght of the inner threaded rod, how it pushes on the ball joint, etc. I guess that to save us $400 they cut out the guy who makes sure that every mirror has the rod tightened exactly right.
Old May 16, 2006 | 10:27 AM
  #162
buzzardmountain's Avatar
buzzardmountain
Thanks gringott, maybe the Autotecknic isn't an inferior product after all.
Edit-Can't wait to get mine!
Old May 16, 2006 | 10:52 AM
  #163
Chebosto's Avatar
Chebosto
those ball stud joints are universal products.
the only thing autotecknic should be knocked for would be the way they poured the aluminum base and the cf mirror housing construction....
everything else, i bet would be the same pieces used by craftsquare since they're just normal hardware you can purchase from a catalog somewhere..
Old May 16, 2006 | 10:54 AM
  #164
gringott's Avatar
gringott
Default Did everyone get this driver's mirror?
Does yours look like this? Just wondering.
Old May 16, 2006 | 10:58 AM
  #165
gringott's Avatar
gringott
Yes my base has some pinholes that could have been filled. But for this price on a piece that is basically a fashion statement - on for a season or so...I am quite happy. And I see what you mean about the top washer Cheston - the curve of the mirror housing leaves a small gap at the leading edge. I think a minute or two with my dremel will make that washer fit just right...
Old May 16, 2006 | 11:55 AM
  #166
RA11325's Avatar
RA11325
how much lighter than stock are these?
Old May 16, 2006 | 12:08 PM
  #167
BJF2K's Avatar
BJF2K
https://my350z.com/forum/showthread.php?t=191118
Good write up, and like I said in that thread, if you tighten it enough then you shouldn't have any problems.
Since most of the people who buys this mirror are putting it on themselves, I guess it wouldn't hurt to tighten the joint before installing!
Old May 16, 2006 | 12:47 PM
  #168
omernazeer84's Avatar
omernazeer84
anyone want to sell me their passenger side oem assembly. preferably superblack.
Old May 16, 2006 | 01:04 PM
  #169
buzzardmountain
When mine arrives, I'll PM you. My car is SB.
Old Jun 13, 2006 | 03:23 PM
  #170
Chebosto's Avatar
Chebosto
update.
i took my mirrors off to paint and to double check the stem length.
the stem is actually threaded about 3/4" deep, however, it is solid at the bend and not hollow, therefore you are limited to no more than 1/4" lowering/cutting off the top of the stem to reduce the height of the mirror and not have the bottom of the CF mirror interfere with the bend in the stem.
the base has some pits (due to the casting process) and can be filled using a slight application of bondo and doing a 250 grit sand, followed by a couple of passes of primer and a 400 wet sand..
i'll post picts of semi-gloss black paint when i'm completed..
Old Jun 14, 2006 | 05:50 AM
  #171
buzzardmountain
Thanks Cheston, can't wait to see pics.
Old Jul 12, 2006 | 09:52 PM
  #172
alan00000's Avatar
alan00000
ntnsracing-9350 Just ordered my mirrors YES!!!
Old Jul 13, 2006 | 05:27 PM
  #173
INTENSEPOWER's Avatar
INTENSEPOWER
Vendor - Former Vendor
Alan,
Thanks for your purchase. Your order shipped today. My Shipping Manager emailed you the tracking number a few minutes ago.. Thanks again. D.
Old Jul 14, 2006 | 06:32 AM
  #174
NA&CH's Avatar
NA&CH
Was there a price increase on these mirrors?
Old Jul 14, 2006 | 08:16 AM
  #175
Alpha's Avatar
Alpha
Originally Posted by INTENSEPOWER
Alan,
Darren,
Have mine shipped yet??
Old Jul 14, 2006 | 08:47 AM
  #176
INTENSEPOWER
Hello,
Yes, a couple of months ago. There's another thread floating around here that covers that subject. d
Old Jul 14, 2006 | 08:48 AM
  #177
INTENSEPOWER
Originally Posted by Alpha
Darren,
Hello,
PM me your info plez. I'm assuming that you ordered black cf, as they have been on b/o for a minute now. Alan ordered silver cf, which we had 3 in stock. As far as the b/o being filled on the black cf, we were advised that they're on their way to us, and we should see 'em any day now. D.
Old Jul 14, 2006 | 09:17 AM
  #178
Alpha's Avatar
Alpha
Sounds good.
Old Jul 14, 2006 | 09:55 AM
  #179
alan00000's Avatar
alan00000
Alan,
Ohh yeah!!! no email though?
Old Jul 14, 2006 | 10:09 AM
  #180
INTENSEPOWER
Alan,
U have PM. D.
