How to: Debadge
Old Nov 7, 2006 | 09:54 AM
JKs350's Avatar
JKs350
Default How to: Debadge
Ok so I've been searching for about an hour now about how to remove the side Z emblems on the fenders. I am looking to replace them. If theres another thread already (which im sure there is, I just cant find it) just post the link. Thanks guys.
Old Nov 7, 2006 | 10:14 AM
97supratt's Avatar
97supratt
Its very easy. All you need is fishing line and a hairdryer.
Step one: Use hair dryer to heat up the adhesive on the reverse side of the emblem.
Step two: carefully use the fishing line and remove adhesive and badge.
If for some reason you still have some adhesive left on your paint use a soft towel with soapy water and clean it off.
Old Nov 7, 2006 | 10:23 AM
kourosH's Avatar
kourosH
thanks
Old Nov 7, 2006 | 10:26 AM
JKs350's Avatar
JKs350
Thanks a lot. Will floss work as well? Should I use the wax floss?
Old Nov 7, 2006 | 10:30 AM
jtabraham's Avatar
jtabraham
Waxed floss will also work fine. Just make sure you're heating up your emblems enough with you're hairdryer, otherwise the floss/fishing line will rip through the foam of the double-side tape instead of the adhesive.
If you still have tons of foam left from the tape, you can remove it by rubbing your fingers back and forth on it and applying pressure while heating it up with the hairdryer. Clean all the residue off with some Goo-Gone (or similar non-caustic adhesive remover) and a soft towel.
Old Nov 7, 2006 | 10:42 AM
97supratt's Avatar
97supratt
I tried the floss method once, but my emblems started smelling like mint. lol j/k
Old Nov 7, 2006 | 10:53 AM
jtabraham's Avatar
jtabraham
I bet they were free of plaque and tarter though!
Old Nov 7, 2006 | 11:14 AM
97supratt's Avatar
97supratt
Yup, then I washed the rest of the adhesive off with scope.
Old Nov 7, 2006 | 12:54 PM
Voboy's Avatar
Voboy
boiling water and flossing works too
Old Nov 7, 2006 | 07:07 PM
kPaNdA350's Avatar
kPaNdA350
If you debadge, will it have holes where the emblems were? I'm guessing not becuase its glued on there?
Old Nov 8, 2006 | 05:23 AM
jtabraham's Avatar
jtabraham
The Nissan Hamburger symbols will have holes under them, but not the "350z" emblem
Old Nov 8, 2006 | 07:16 AM
noodleman's Avatar
noodleman
he's talking about the side emblem though...and there are holes iirc behind the two "Z" emblems on the front fenders.
Old Nov 8, 2006 | 07:39 AM
97supratt's Avatar
97supratt
Even if it has holes, to remove the emblem you have to use either fishing line or dental floss.
SKiDaZZLe
Aug 5, 2021 09:06 AM
CMiS2K
Texas
Aug 27, 2003 01:20 PM
Toony
Oct 14, 2002 10:30 PM
