Calling all LED/lighting experts
Old Mar 9, 2007 | 11:49 AM
ESPO 774's Avatar
ESPO 774
Default Calling all LED/lighting experts
How can i make this effect similar to the JDM underseat "ambiance" lighting kit. I want the same look of a dim amber light, but I do not want to pay the $120+ for the Kit from japan. Can i just get some amber LEDs and tap them into the headlight wire? how would i go about this?
thanks in advance
Old Mar 9, 2007 | 12:00 PM
eat rice z33's Avatar
eat rice z33
Sure you can build your own kit, just do some online shopping for LED's and see if you can buy nice little housings for them, thatway you can install them and theyll look OEM, when wiring them up, you will need to buy some resistors depending on the LED voltage. So select LED's, select housing, then calculate proper resistors with V=IR V in volts, I in amper, R in ohms. you can also use a small bread board hook up a resistor circuit to limit voltage, and then parralell the leds off that board. you can also hookt hem up in series, which would require uneccesary calculations. Should only cost about 15 bucks all said and done!
Old Mar 9, 2007 | 12:02 PM
ESPO 774's Avatar
ESPO 774
wow, that would be great. only i know nothing about resistors, and hooking up break boards, etc. darn, any advice?
Old Mar 9, 2007 | 12:03 PM
jimmyloose's Avatar
jimmyloose
http://www.hidplanet.com/forums/view...8294c3cf5b431c
All the LED info you'll ever need. The moderator of the LED section is pretty much the LED master.. next to acree
Old Mar 9, 2007 | 12:14 PM
z350boy's Avatar
z350boy
One word of advice>>>>>SEARCH !!!
Old Mar 9, 2007 | 12:29 PM
ESPO 774's Avatar
ESPO 774
die.
Old Mar 9, 2007 | 12:30 PM
THE TECH's Avatar
THE TECH
Seems like a lot more work than just buying the premade Nissan kit.
Old Mar 9, 2007 | 12:33 PM
rcdash's Avatar
rcdash
you can buy LEDs designed for 12v systems and you don't need to solder in resistors that way. Email folks at ctlumination or superbrightleds and they will get you hooked up for less than $10 per bulb. They're bright enough you'd only want one per foot well.
(it's hard to search for this kind of stuff guys cause the stupid search engine requires 4 characters and LED is 3; give him a break)
Old Mar 9, 2007 | 03:32 PM
ESPO 774's Avatar
ESPO 774
this is available from superbrightleds.com....Is this what i am looking for? too bad it doesnt come in amber, could i swap the led for an amber one?
LED Wired - 12 VDC
LED with 3 foot long 30ga. stranded wired
Built-in resistor for 12 Volt DC operation (10~14 Volt range)
Made with our brightest 30 degree Viewing Angle LEDs, Black Nylon panel mounting bezel included
Old Mar 10, 2007 | 05:55 AM
ESPO 774's Avatar
ESPO 774
Old Mar 10, 2007 | 12:57 PM
evolved326's Avatar
evolved326
Buy lights then put them on the inside of your car. Then it will be bright.
Old Mar 10, 2007 | 01:14 PM
ESPO 774's Avatar
ESPO 774
what???
Old Mar 10, 2007 | 01:19 PM
Nexx's Avatar
Nexx
+1
Old Apr 26, 2007 | 03:27 PM
350ZIvy's Avatar
350ZIvy
you need the LED bar, which you can put them under seat.
m_0g
Jun 3, 2021 10:05 AM
burglapfd
Dec 6, 2020 01:04 PM
carid
Misc.
Sep 10, 2015 06:16 AM
