LED vs normal bulbs
Old Mar 20, 2007 | 03:22 PM
d!abolic's Avatar
d!abolic
Default LED vs normal bulbs
I've been using LED turnsignals for nearly a year and I've come to realize that they're extremely difficult to see during the daytime. Sure they're bright as hell during the night, but when it's bright out, all you see is that tiny blinking dot. I'm seriously considering switching to normal (though white, not amber) bulbs. Which ones should I be looking at?
Old Mar 22, 2007 | 08:19 PM
d!abolic's Avatar
d!abolic
Can someone help?
Old Mar 22, 2007 | 09:38 PM
drifter23's Avatar
drifter23
I have the Polarg Visuals on my car. And they have been working well for over 1 year. I have the hyper white bulbs for my front turn signals. I have used LED's but they always went bad after a few months. There are a lot of bulb brands out there. And everyone has there own preference.
Old Mar 30, 2007 | 08:05 PM
d!abolic's Avatar
d!abolic
So are regular white bulbs brighter than LED in the daytime?
Old Mar 31, 2007 | 02:12 PM
Shift_Z33's Avatar
Shift_Z33
I'd stick w/ a regular bulb since it will be reflected and an LED would not be. Nothing wrong with the oem bulbs.
Old Mar 31, 2007 | 04:16 PM
d!abolic's Avatar
d!abolic
So is that why regular bulbs are brighter in the daytime (presuming that I'm not imagining this)? Regular bulb makes the entire reflective surface light up and LED doesn't?
Old Apr 2, 2007 | 07:18 AM
MidnightG35X's Avatar
MidnightG35X
Regular bulbs have a higher viewing angle (~360 degrees) They radiate light in every direction. LED's are generally very directional. Most common LED's are anywhere from 15-30 degrees. You can get LED's with higher viewing angles (70-120 degrees), but they generally cost more. That is why regular bulbs light up the entire surface while LED's do not.
As for the regular bulbs being brighter in the day, I'm guessing that is because all of the energy is focused at the filament of the bulb, so it is more intense. LED light is generally spread across multiple LED's, so each individual one is dimmer compared to a single regular bulb.
Old Apr 6, 2007 | 08:15 PM
d!abolic's Avatar
d!abolic
Alright, so where do I buy good, clear turn signal bulbs?
Old Apr 26, 2007 | 03:09 PM
350ZIvy's Avatar
350ZIvy
check www.iJDMTOY.com, I bought a pair there. Ask them, they should have that in stock.
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
codek
Sep 28, 2015 03:03 AM
