the best way replacing an emblem is...?
Old Sep 20, 2007 | 07:47 PM
cviljin's Avatar
cviljin
Default the best way replacing an emblem is...?
hello...i searched for this but only came up with "Where do I get these emblems..." and Selling Emblem posts
My question is: What is the best way to replace the stock 350z emblem and the Nissan Emblem without scratching/damaging the car. I tried using google and other search engines and they gave me answers that require a screw driver, and I don't plan on using that = /
Also What is the best way to put an emblem on?
Thanks in advance
Old Sep 20, 2007 | 07:53 PM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
I'm not for-sure positive on this method,.... but I have read somewhere on this site that if you use a hair dryer or heat gun to heat up the emblem, then you can use fishing line with both hands and pull down slicing thru the glue that you have heated up.
I would test this out on something besides your car first.
Good luck !
Old Sep 20, 2007 | 07:55 PM
Swiffer's Avatar
Swiffer
The hair dryer/fishing line method has worked for many people.
Old Sep 20, 2007 | 07:57 PM
Jay'Z's Avatar
Jay'Z
I used a screw driver.. With a t shirt wrapped around it of course
Old Sep 20, 2007 | 07:59 PM
350zxtaz's Avatar
350zxtaz
+1 on the fishing line...
FYI- there are holes behind the Nissan hamburger emblem just in case you weren't planning on putting something over them.
cviljin's Avatar
cviljin
Yeah i was just talking to my friend about it and he said to use a hair dryer and just use floss or something. but hey Jay'Z when you used a screw driver it didn't scratch up the paint or anything? and was this for the 350z emblem or the nissan?
Old Sep 20, 2007 | 08:44 PM
Yokohamaz's Avatar
Yokohamaz
I used Goo Gone and one of those plastic tools used to pop your doors off. No scratching.
If you have a roadster, there are no holes.
Old Sep 20, 2007 | 09:17 PM
PFI350Z's Avatar
PFI350Z
Good luck !
man i debadged my car... i used a old credit card... no heat gun or nuttin
Old Sep 20, 2007 | 09:18 PM
PFI350Z's Avatar
PFI350Z
for my old car... didnt do it to the Z yet
Old Sep 20, 2007 | 09:20 PM
PFI350Z's Avatar
PFI350Z
Question: the Nissan symbol in the back... holes behind it?
Question: im pretty sure it doesn't but the 350Z badge doesnt have holes rite?
Question: How bout the Z's in a circle on the front fenders?
Old Sep 20, 2007 | 10:50 PM
Yokohamaz's Avatar
Yokohamaz
I think the coupe has holes in the hatch. But i know the roadster doesn't on the trunk.
Old Sep 21, 2007 | 12:58 AM
Z_Driver's Avatar
Z_Driver
Master
Good luck !
This works but, be careful you can saw into the clearcoat if your not careful.
Heat first and try to pull up with steady pressure with your finger nails or with a plastic putty knife. If that doesn't work use the 15lbs fishing line and pull evenly through it. If it's still not coming up, saw slowly and easily with the fishing line. That's what I had to do. Clean off glue residue with lighter fluid. Then clean lighter fluid off with windex or soapy water because the lighter fluid may dull your finish. Lighter fluid is safer than go gone that a lot of folks use and it's cheaper too.
Z_Driver's Avatar
Z_Driver
Master
Yes, this is true ...
Old Sep 21, 2007 | 01:00 AM
Z_Driver's Avatar
Z_Driver
Master
Question: the Nissan symbol in the back... holes behind it?- Yes
Question: im pretty sure it doesn't but the 350Z badge doesnt have holes rite? - That's correct.
Question: How bout the Z's in a circle on the front fenders? - It does have locator holes
In line responses....
Old Sep 21, 2007 | 01:23 AM
blazed54's Avatar
blazed54
no need hair dryer. just leave your car in the sun at midday. and your car should be hot enough to slice through the glue with regular floss (don't have fishing line). and then goo gone or something similar. once the goo gone soaks through the adhesive you should have a pretty easy time rolling the adhesive off with your thumb (don't try to scratch it off with fingernail).
Old Sep 21, 2007 | 01:30 AM
Z_Driver's Avatar
Z_Driver
Master
You know floss might be better as long as it doesn't break. I guess you could double it up. I'll have to try that next time. The waxed type would probably protect the clearcoat a bit more. Mine scratched just a little bit. But, that went under the newer smaller rear emblem so it all worked out OK.
Old Sep 21, 2007 | 02:55 AM
Z04's Avatar
Z04
https://my350z.com/forum/showthread....+nissan+emblem
Old Sep 21, 2007 | 05:16 AM
Kuruma-san's Avatar
Kuruma-san
there ya go
Old Sep 21, 2007 | 05:52 AM
PFI350Z's Avatar
PFI350Z
Old Sep 21, 2007 | 05:56 AM
PFI350Z's Avatar
PFI350Z
i found the answer... thanx
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
