Rev limit beeping sound mod?
Old Oct 22, 2007 | 01:59 PM
_Fayte_'s Avatar
_Fayte_
Default Rev limit beeping sound mod?
Did anyone do a mod where if the rev limit is reached, there'd be a continous beeping sound? I figure this would be a lot more useful than just a blinking red light.
Old Oct 22, 2007 | 03:38 PM
punish_her's Avatar
punish_her
You woud have to get into the wiring diagram alittle. The only thing you would need to do is wire a sound device in line with the hot side of the led on the inside of the cluster. It would take a little work but not impossible.
This way you still have the factory adjustable light.
Old Oct 22, 2007 | 03:53 PM
Tackett's Avatar
Tackett
this is a good idea. if you do something like this.. try hooking it up to a switch and mounting the switch on the dashboard so you can turn it on and off. be sure to do a write up with pics. Good luck. good idea.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
