Need help adjusting headlights please
Old Mar 27, 2008 | 08:50 PM
Coehsp350Z's Avatar
Coehsp350Z
Default Need help adjusting headlights please
I need help on adjusting my left headlight. the beam is a little bit lower than my right headlight and i want to even it out. Where can i find the adjust screw/nut??? I just bought my car 2 days ago and im still learing everything about it. any help is appreciated.
Old Mar 27, 2008 | 09:18 PM
usmanasif's Avatar
usmanasif
Left headlight is meant to be lower than right to avoid blinding oncoming traffic. It is the same way for the right light in the UK. You can raise it, but it is not going to be a uniform beam of light as the right since both sides are aimed at exactly the same height, the left side just has a different cut-off shield.
Old Mar 27, 2008 | 09:45 PM
Coehsp350Z's Avatar
Coehsp350Z
Oh ok, thanx for the info. As i mentioned im still new to this whole new Z thing. Im still learning, thanx for the help
Old Mar 27, 2008 | 09:51 PM
Spork's Avatar
Spork
You can raise them a little and have them light better. But don't raise them enough to the point that they're blinding people.
There's a DIY on aiming the headlights somewhere. I'll dig it up.
Old Mar 27, 2008 | 11:49 PM
Willowns's Avatar
Willowns
Its not really aiming it up or anything. there is a so called "****" of sorts thats you can turn. you will need a 16" screwdriver but it is very easy and works gr8.
just go to google and type this in
"350z headlight adjustment"
the first link provides a very good write up. qucik and easy
(I would have just psoted a link but it wont let me)
Old Mar 28, 2008 | 01:55 AM
redlude97's Avatar
redlude97
they have the same cutoff shield
Old Mar 28, 2008 | 09:01 AM
usmanasif's Avatar
usmanasif
I could certainly be wrong, but everything I have ever read on these and other forums always says that the light shield's cutoff "step" is different between the left and right projectors with the left one being raised a little, hence both lights are aimed at exactly the same height, but the left one projects light at a lower level than the right.
Old Mar 28, 2008 | 04:22 PM
redlude97's Avatar
redlude97
Yep. I don't know what sites you've been reading
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
