Headlight hazyness any ideas
Old May 23, 2008 | 01:14 PM
350z 7k's Avatar
350z 7k
Unhappy Headlight hazyness any ideas
Looks like water or something how can i fix it
Old May 23, 2008 | 01:27 PM
CSF's Avatar
CSF
is that inside or out?
Old May 23, 2008 | 01:28 PM
Jun's Avatar
Jun
meguiar's plastic polish.
polish away with a nice clean microfiber towel.
if it doesn't come out, then it's the inside.
Old May 23, 2008 | 01:33 PM
CSF's Avatar
CSF
^^if on outside...meguiar's plastx
Old May 23, 2008 | 01:52 PM
Z04's Avatar
Z04
on the first page just a few threads down
https://my350z.com/forum/exterior-and-interior/360369-hazy-headlight.html
wow, not only can some not search, they can not scroll either
Old May 23, 2008 | 11:29 PM
lbz's Avatar
lbz
if the plastic polish has no effect, its on the inside which means you have either a small crack somewhere or a bad seal.
If it does have an effect but you are not satisifed, recommend take it to a detailing or body shop and have them buff it out.
I had a crack in my passenger side from a very slight fender bender. I pulled the lens off (after heating), got the water out, wiped down the inside of the lens and sealed the crack from the inside with RTV and it worked great.
Old May 24, 2008 | 06:01 AM
ladyzed's Avatar
ladyzed
I am a professional detailer - I'll chime in.
When I bought my Z a few months ago I noticed this too. I too used the Meguiars plastic polish, however being the neat-freak I am, and how careful I can be, I used a power polisher.
I don't recommend using one because an inexperienced person can burn a hole right through. I used a 3000 grit polish with a 100% lamb wool pad then a resin-based glaze with a 9000 grit foam pad to finish it off.
Lens look 100%. I also did this the the dulled tail lights.
Old May 24, 2008 | 11:32 AM
j.arnaldo's Avatar
j.arnaldo
Maybe you meant haziness?
Uriyo_
Sep 8, 2021 08:46 AM
07ZEKE
Aug 23, 2021 09:15 PM
Dsowe
Feb 17, 2021 10:38 AM
Alexreyes
Sep 30, 2015 11:30 PM
JGee450
Sep 30, 2015 04:32 AM
