Help, I Need Somebody To Help W A ? On Aftermarket Led Taillights
Old Sep 20, 2008 | 09:35 AM
iwantaz123's Avatar
iwantaz123
Default Help, I Need Somebody To Help W A ? On Aftermarket Led Taillights
I bought a set of tail lights that are supposedly for a 2006 nissan 350z, they are aftermarket led tail lights off of ebay. The connector doesn't directly plug into the plug that comes off of the car. Am i missing something or does this connect to only the 03-05 350zs...please help yalll!!!
Here is the link to the tail lights i purchased.
http://cgi.ebay.com/ebaymotors/_Car-...=p4506.c0.m245
Old Sep 20, 2008 | 09:40 AM
Spork's Avatar
Spork
What the hell kinda connection is this???
Old Sep 20, 2008 | 12:36 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
You got hosed. That connector won't work with ANY year Z.
Old Sep 20, 2008 | 12:41 PM
03aeroZ's Avatar
03aeroZ
if i remember correctly, you unplug your light and plug that into where the bulb used to be.....i could be WAY off though. had a set of tails like that and i am thinking that is what i had to do. again, i could be WAY off.
Old Sep 20, 2008 | 01:40 PM
300zx1985's Avatar
300zx1985
Thats what you get for buying those ugly tails
Old Sep 20, 2008 | 03:14 PM
whiskeycheeks's Avatar
whiskeycheeks
yea you unplug your bulb and they connect
Old Sep 20, 2008 | 06:48 PM
iwantaz123's Avatar
iwantaz123
thanks jackass.... anyway, I'm still not getting how these will hook up to my connector coming from the car of an 06 that original is set up for the stock LED tail lights...can anybody explain further or verify that they will work????
Old Sep 20, 2008 | 07:43 PM
VENOMSZ's Avatar
VENOMSZ
I know that alot of folks that bought those eBay lights claimed to have several electrical issues...
I don't know if they are worth the time and effort for all the problems.
Your car, your call.
Old Sep 21, 2008 | 07:47 AM
iwantaz123's Avatar
iwantaz123
Any other help on how to connect to an 06 350z???
Old Sep 21, 2008 | 09:51 AM
VENOMSZ's Avatar
VENOMSZ
Have you tried shaving the plugs?
I have the JDM clear tails, and had to shave the plugs
to make them fit. Try to see if the right side fits the
left connection...or vice versa. That is the only thing
that I can think of
Old Sep 22, 2008 | 10:47 AM
matix101vz's Avatar
matix101vz
u have to twist out the bulb on the stock and plug that in but ebay tail lights r GARBAGE. they use diff volts then your stock and it will put your car in super limp mode, return them while u can n get the real dea lights ... dont cheap out
Old Sep 22, 2008 | 10:56 AM
Waiz's Avatar
Waiz
Dude, you need to return those.
It should be a simple plug and play like the OEM, these look suspect.
Old Sep 24, 2008 | 07:59 AM
dirty_215's Avatar
dirty_215
Whatever man, yopu brought the tail lights cause you like them so fu*k what the other cats say. They got there taste and you got yours. As long as you like them you good. All you need to do is pull the bulb and they connect in place and the screw in the second bulb and you'll be just fine.
Old Sep 24, 2008 | 09:49 AM
Changvi's Avatar
Changvi
My rule of thumb is its either OEM or JDM. Good luck on making them work. If it does work, post some pics...
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
SharX59
Sep 27, 2015 09:23 AM
