Mastergrade CF Hatch...
Old Dec 14, 2008 | 01:35 PM
Nismo350Z_00's Avatar
Nismo350Z_00
Exclamation Mastergrade CF Hatch...
I did some searching and i couldnt find much...What kind of glass do people put in the hatch? how weatherproof is it? does anyone have problems with leaks? Is it the same shape as the OEM glass?
Old Dec 14, 2008 | 01:36 PM
r_seng's Avatar
r_seng
OEM size, OEM glass can be used.
Old Dec 14, 2008 | 01:42 PM
INTIMAZY's Avatar
INTIMAZY
OEM glass is fine.
There are a few lightweight lexan options available as well.
Sealing should be excellent as long as installed properly with either option.
Keep in mind, you would NOT want to run a rear wiper with lexan.
Old Dec 14, 2008 | 03:23 PM
Jim@Showstoppers's Avatar
Jim@Showstoppers
You have two options:
Lexan rear window kit: much lighter in weight, can't be tinted unless sprayed, no rear wiper, no rear defrost. Roughly $200-$275
OEM glass swap: Heavy. Roughly $100 to get your OEM glass swapped.
Old Dec 15, 2008 | 08:40 AM
Done Deal DR's Avatar
Done Deal DR
^that sums it up perfectly.
Love the Mastergrade hatch, whatever happened to V2 hatch you hinted at like 6 months ago Jim???
Old Dec 15, 2008 | 09:55 AM
Jim@Showstoppers
It was put on the backburner. We will be discontinuing the MG hatch once the new hatch is released.
Old Dec 15, 2008 | 11:53 AM
Done Deal DR
Just tell me there is an integrated lip, thats all I want to hear Jim. If it's anything like the G35 trunk lid you debuted on the same post you hinted on the v2 Mastergrade hatch, I'm all in brother!
Old Dec 15, 2008 | 01:43 PM
Escobar's Avatar
Escobar
lexan is the way to go...
Old Dec 17, 2008 | 06:17 PM
Archaismic's Avatar
Archaismic
i have an 03 track and the mastergrade hatch... stayed with stock glass cause i live in WA and with humidity you really want the defogger... on another note... anyone have any advice for keeping the brake light in place... the CF is a lot thicker and doesn't perfectly mimic the stock hatch for the mounting of the light... tried a strip of velcro but it still falls down... not sure if anyone really even keeps the light when they get the new hatch...
Andy@Performance
Jul 27, 2007 08:32 PM
Just one slow Z
May 21, 2005 06:59 PM
masterperi
Mar 7, 2005 11:50 AM
