Need some help with tail lights
Old Mar 17, 2009 | 03:14 PM
06z33's Avatar
06z33
Default Need some help with tail lights
Whats up guys. I just got a set of the "oem style" tail lights off of ebay (i know i know, but whats done is done). I have an 06 z and the tail lights say that it fits the 03 to 06z. However the plugs dont seem to fit at all and I see no way they can work. If anyone has installed aftermarket tail lights on their 06 and up please help me out.
Here are some pics. The first one is what the after market tail light needs to plug into and the other two are the tail light's plug from two views.
thanks in advance.
Attached Thumbnails Need some help with tail lights-img00093.jpg   Need some help with tail lights-img00094.jpg   Need some help with tail lights-img00095.jpg
Old Mar 17, 2009 | 03:33 PM
Zenica's Avatar
Zenica
Are the eBay lights also LED? The 2006 had LED, correct?
Provided it will work once connected, then your problem is in making that
connection. More aptly put, in connecting two incompatible male/female connections.
You can either salvage the required male plug from your OEM lights (That I'd like to buy
if they are LED) or you can find a salvage yard unit to remove the plugs from or you can
abandon the OEM end of the harness as well as the end on the eBay lights and use your
own set of male/female plugs.
This would require soldering and cutting the OEM wires. Not the route I would take.
PM me if you want to unload those OEM lights, provided they are LED.
Old Mar 17, 2009 | 04:44 PM
bballgms's Avatar
bballgms
i would also like to purchase ur LED 06 lights if u want to part with them. arrrr Zenica we have a battle lol.
Old Mar 17, 2009 | 06:31 PM
06z33's Avatar
06z33
I dont think you guys want to battle over one perfect oem LED light lol. The reason why I replaced them is because someone hit the driver side one and cracked it. Thanks for the info though Zenica.
Old Mar 17, 2009 | 06:48 PM
Zenica's Avatar
Zenica
Depending on what you want for it, I'm still interested in it.
Would leave me with one less tail light to look for!
Old Mar 17, 2009 | 07:10 PM
vishalzzz's Avatar
vishalzzz
your doing it wrong.. just take out the bulb, and plug in the wire that is on the ebay lights into where the bulb goes in the socket.
Old Mar 17, 2009 | 07:13 PM
03aeroZ's Avatar
03aeroZ
Old Mar 17, 2009 | 08:29 PM
06z33's Avatar
06z33
^^ not sure what you mean. Which bulb from the socket?
Old Mar 17, 2009 | 08:44 PM
Prone's Avatar
Prone
Those are LEDs, there are no bulbs per say. You can't plug it the way it is now, you have to use your brain and a multimeter and figure out what is ground , what is running light 12v and what is brake light 12v. From there I would suggest you cut the female end off your broken tail light and the oem non-damaged one and also cut out the plugs from the new taillights and retrofit the connectors to make it look oem, or solder the wires individually after you cut the connectors out. Since money is an issue ( I'm assuming this was the case, or else why didn't you buy an oem set) your best bet is to find someone that can guide you through the process of cutting the wires and making a good connection. If you had the knowledge to do such thing this thread would not excist, so I am assuming you lack said knowledge therefore advising you to have someone with experience handle this.
Old Mar 17, 2009 | 09:29 PM
vishalzzz's Avatar
vishalzzz
dude. This is simple. You know how you take out the light bulb on your oem lights. Take the bulb out by twisting the socket out of the taillight. Then take the bulb out and then put that wire from the eBay lights where the bulb was. simple
Old Mar 17, 2009 | 09:48 PM
Prone's Avatar
Prone
What light bulb? THEY ARE LEDs! Man! 06+ have no light bulbs in the brake light housing last time I checked.
Old Mar 17, 2009 | 09:52 PM
vishalzzz's Avatar
vishalzzz
just sell those lights. And get oem ones. I bougt those led eBay ones for $160 and used em for 4 months and sold them for $300 on craigslit on my 03 Z haha
Old Mar 18, 2009 | 07:38 AM
06z33's Avatar
06z33
^ well you douche bagged someone lol. And yes money is an issue, because unfortunately I can take care of my car but some *******s just hit my light and cracked it. Now I dont have the money to spend on oem ones right now but I also dont want a ticket, hence the situation im in now. And prone, my brother can do what you said for me, I just feel that if it was advertised as 03-06 I shouldnt be doing this. Thanks for the help guys.
Old Mar 18, 2009 | 09:56 AM
Prone's Avatar
Prone
I didn't mean to come off sounding like a d**k, I just don't want you to get into a bigger mess than you are already in because you didn't do it right the first time. I totally understand where you are coming from, ebay stuff is not the best stuff out there and I guess whoever sold them to you didn't know the difference between 03-05 lights and 06+ lights. Hopefully your brother will help you on this. Good luck.
Old Mar 18, 2009 | 12:41 PM
06z33's Avatar
06z33
^no problem lol. I never took it that way to begin with. Thanks for the help
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
