Remove Stock Spoiler?
Old May 30, 2009 | 09:54 PM
VBoi88's Avatar
VBoi88
Default Remove Stock Spoiler?
So i just bought me a nismo spoiler, so now i want to take the stock spoiler off, and i was wondering how do i remove the stock one? I took the 2 screws under the hatch out already but it doesnt seem to come off, is there any other things i need to do to take the spoiler off? Thanks
Old May 30, 2009 | 09:59 PM
tanabe350z's Avatar
tanabe350z
should be taped down, or glued i cant remember. maybe im wrong but i would ask a local body shop
Old May 30, 2009 | 10:18 PM
03brembo's Avatar
03brembo
heat it up with a hair dryer around the edges and run a string through it to peel it off kinda, same idea as removing a badge
Old May 30, 2009 | 11:30 PM
350ZTheStandard's Avatar
350ZTheStandard
Mine has 4 screws on it when I put it on my Z car, plus 3M double sided tape.
Attached Thumbnails Remove Stock Spoiler?-back-end-0404.jpg   Remove Stock Spoiler?-full-template-0395.jpg
Old May 31, 2009 | 03:24 AM
Venom8.1's Avatar
Venom8.1
good work
Old May 31, 2009 | 04:00 AM
WalkerT's Avatar
WalkerT
Professional
Yes there is double sided 3m tape around it. The best way to not hurt your paint is to take dental floss and slide it under one corner and move it back and forth until you can start to pull it up. Helps to doulbe up the floss so it does not break. Do it on both sides.
Old May 31, 2009 | 04:01 AM
WalkerT's Avatar
WalkerT
Professional
If your dealer install an aftermarket oem spoiler (like mine) then there is only two bolts.
Old May 31, 2009 | 06:15 AM
VBoi88's Avatar
VBoi88
thank you guys, will try to do it.
Old May 31, 2009 | 10:52 PM
350ZTheStandard
The stock spoiler has 4 bolts on it, like in the pics above.
Good luck
sales@czp
Sep 23, 2019 03:30 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
