I have a question about rear strut bar Z logo.
I was looking for a part number or part name for rear strut bar Z logo.
Today I mistakenly removed this z logo. because the logo was getting worse cuz of sun. But the problem is this logo has attached with some sort of bond.
And it had not popped out clearly. Some part of Z logo still remain and it look bad. Is there anyone know how to remove Z logo on rear strut bar? I really need help! I don't know how to remove or replace it clearly.
It may not be a simple stick on like the exterior logo. A mild acid, such as vinegar, may remove epoxy. Problem is if you go with a stronger acid it will remove epoxy but destroy everything else.
You have to pop the covers on either side of the center piece first. Then you can pop off the center piece. You can then drill out the pegs / clips that are holding the remaining piece of the logo from underneath the center piece.
To get the side covers off, you have to pull up the hatch seal and pull the upper trim pieces off. After the seal is pulled up, just get in there with your fingers and give it a good pull, they will pop right off.
Then do the same thing at the outside end of each of the pieces on the side of the strut bar.
You can get a nice chromed emblem from CourtesyParts.com. Actually, they come in pairs for something around $30.
I used bluebatmobile's overlay on mine, but i eventually removed that and just painted it (With the black Z still) because the color match was better the the overlay. You can find factory colored spraypaint through duplicolor's website if you want to paint match to your car. Been two years now, ant it still looks like the day i did it!
Here's my link when i did the overlay, it came out good, but took a while to get all teh wrinkles out.
https://my350z.com/forum/exterior-an...-ya-think.html
Getting the strut bar cover off is the most difficult part. Once that is off, it will take you all of 60 seconds to grind/drill off the back of the emblem. There is no adhesive to worry about. Good luck!
I am going to paint it and put this on soon.
But I have a question. I bought z emblem on courtesyparts.com but
what bond should I have to use? I guess interior is the most hottest area in summer. So I shouldn't use 3M stickers right? Please give and advise And also thanks about previous advise.. I am really glad I have bought 350z..
This community is amazing! I am loving it. haha..
Get the gray 3M, not the white foamy looking 3M tape. Like many on here, my OEM spoiler is help on by 3M tape alone, and have had zero issues.
Question- do you have a guide on how to get the strut bar's plastic pieces off to remove the Z log off of it?? I want to take it off and paint it silvers since the silver is scratching off over time. Thanks!
Thank you! I did pop off the black plastic cover pieces but i couldnt get the silver strut bar piece that has the logo on it off... a little scared to break it. Ill try again later... but it feel like its mounted on there.
StateNuke08
Oct 31, 2015 05:01 AM
