03 Tail lights to 06-08 LED Tails?
Old May 7, 2010 | 11:45 PM
Knightrider's Avatar
Knightrider
Default 03 Tail lights to 06-08 LED Tails?
Is it a direct plug & play install?
Old May 8, 2010 | 01:14 AM
350ZTheStandard's Avatar
350ZTheStandard
I think u have to reboot the 350Z, to work, what OS are u using???
Old May 8, 2010 | 01:27 AM
Z04's Avatar
Z04
why don't you search and find out
Old May 8, 2010 | 05:17 AM
glenns280's Avatar
glenns280
been talked about 3,568.5 times
Old May 8, 2010 | 07:11 AM
Beast101's Avatar
Beast101
Default @OP, Did this two weeks ago
The answer is no. There is a little bit of wire modification involved. I dont remember which wires go to which because the colors don't match up. You should check the audio/video thread click on the wiring color code guide for your car and 2006, and that should help.
Old May 8, 2010 | 07:39 AM
dkmesa350z's Avatar
dkmesa350z
If your Z is silver or white, you will only need to swap the two wires mentioned above. For all other body colors, you need to completely rewire the harnesses. (06-08 taillights will not work on 03-06 with Frost interiors under any circumstances).
Old May 8, 2010 | 08:22 AM
Spork's Avatar
Spork
The rewire wire for the do swap tails is needed for working correctly. If questions have any let me know tell me feel free to send me a massage and I will try to lead you towards in the correctly direction.
Basically, the wire left white had to go right red one to correctly mesh. Bolts may sometime need to swapped. I could be errors.
Old May 8, 2010 | 10:43 AM
shingr's Avatar
shingr
The US version is a direct swap.
The JDM connectors are different so I swap the harness and all works fine.
Old May 8, 2010 | 04:06 PM
FliPPER_Z's Avatar
FliPPER_Z
lol ..are you serious..lol
Old May 8, 2010 | 10:48 PM
350ZTheStandard
How dare you doubt the word of a fellow my350z member?????
Old May 8, 2010 | 11:01 PM
Hsummer's Avatar
Hsummer
What he said, but he left out the part about making sure you have the correct taillight fluid, you want to make sure it's flux capacitor compatible.
Old May 8, 2010 | 11:08 PM
dkmesa350z's Avatar
dkmesa350z
Good call, totally forgot about that!
Old May 9, 2010 | 08:19 AM
Armitage's Avatar
Armitage
Yes.
Old May 9, 2010 | 05:13 PM
beaufb's Avatar
beaufb
its a simple plug and play. I have done it myself
Old May 11, 2010 | 08:13 PM
Knightrider
One of my pet peeves on this website is when people say "search for it" especially when you have searched every possible section(s). Couldn't find jack sh*t under the "lighting" section or "search" engine.
Anyways thanks to those who actually took the time to give a fellow Z member some tips. But I guess I'm just gonna stick with my '03's. Swapping seems too complicated.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
