New My L.E.D. custom 350z tail light design
Old Aug 19, 2010 | 09:13 PM
1 MEAN Z's Avatar
1 MEAN Z
Default New My L.E.D. "Evil Z" custom 350z tail light design
Here is a look at one of our new 350z "Evil Z" led tail light design coming soon. This is just the first of quite a few designs we are getting ready to release. It comes equipped with 10mm super bright leds for turn signals, reverse lights and the running/brake lights. These tail lights will have three different turn signal options that can be built in. Option A; regular blinking turn signals as shown in the video, option B: chaser turn signals and option C: sequential turn signals. Demo videos of those tail lights will be coming soon The reverse light leds are super bright wide angle and are the same leds we are using in our prototype 350z headlights. We are working on new designs for the upper and lower reflectors at this time. More tail light designs will be coming soon......
Let me know if you have any questions.....
You can find more pics and videos here:
MyLightEmittingDesigns.weebly.com
Thank you for the interest
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/gy_TBmQprPY?fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x006699& amp;color2=0x54abd6"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/gy_TBmQprPY?fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x006699& amp;color2=0x54abd6" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Old Aug 19, 2010 | 10:46 PM
sdZ33's Avatar
sdZ33
how much?
Old Aug 19, 2010 | 11:00 PM
ITOzann's Avatar
ITOzann
nice
Old Aug 20, 2010 | 04:49 AM
silver streak's Avatar
silver streak
what if any rewiring is there to be done?
Old Aug 20, 2010 | 06:36 AM
zaperroni's Avatar
zaperroni
looks great!
Old Aug 20, 2010 | 06:40 AM
gmueip's Avatar
gmueip
Hi Kids!
Sweet! Now we can give Escalades a taste of their own medicine by blinding them with our taillights.
Old Aug 20, 2010 | 09:24 AM
Zquicksilver's Avatar
Zquicksilver
this design is sweet... i would definitely purchase a pair of tails like these!
good job!
Zquicksilver
Old Aug 20, 2010 | 10:17 AM
Jackson0927's Avatar
Jackson0927
that prototype led headlight you fab'd up is pretty freaking crazy. I've never seen anything like that. so do you'd have to buy headlights and tail lights to get this combo eh? just estimating, i bet those will be quite costly.
i want to see some pics of those installed... the led headlights that is.
Old Aug 20, 2010 | 10:18 AM
1 MEAN Z's Avatar
1 MEAN Z
Originally Posted by sdZ33
how much?
It all depends on what options you want built in. Besides just what you see here, you can have the internals painted black,the upper and lower reflectors painted or smoked, you will also have the option of adding an extra row of led work to the lower reflector. We are in the middle of redesigning the led work in the upper reflector to make it better cost and time effective. The old design is going to be retired and a new one released in its place.Something that will compliment the use of 10mm leds in the lower reflectors. May try and do some R&D on a CCFL lighting option for the upper reflector if we can find a set up that is small and bright enough. There are quite a few ideas being passed around My L.E.D. right now on different design options. I can add you to our notification list if you would like so you can receive email updates on new project, products and specials going on at My L.E.D., just PM me your email address and I will add it to our list..
Old Aug 20, 2010 | 10:20 AM
1 MEAN Z's Avatar
1 MEAN Z
Originally Posted by ITOzann
nice
Originally Posted by zaperroni
looks great!
Thank you!
Old Aug 20, 2010 | 10:25 AM
1 MEAN Z's Avatar
1 MEAN Z
good job!
Zquicksilver
Thank you...I can add you to our notification list if you would like so you can receive email updates on new project, products and specials going on at My L.E.D., just PM me your email address and I will add it to our list. Then when these are released for sale you will be notified and can stop in for a quote on a set customized how you want.
Old Aug 20, 2010 | 10:37 AM
1 MEAN Z's Avatar
1 MEAN Z
The reverse/turn signal option does require a little modification to the harness in your Z. It is fairly simple; you would only have to tap in to the two wires leading to your stock reverse light, one being positive and the other negative. These are easily accessible once you remove your tail lights. The turn signals are fairly easy to tie into. This harness is also easily accessible, it is in the same location as your reverse light harness as they are located in the same housing.Your first option would be to tie in and leave your existing turn signals hooked up along with the custom turn signals.Your second option is to cut the two wires going to your existing turn signal in turn deleting them, then run the two wires you cut to the turn signal harness off the back of your custom tails.The fully modified custom tails come with new harnesses one end pre-wired to the tail lights and the other end will have to be wired in to your existing harness.
Thanks for the interest...
Old Aug 20, 2010 | 10:52 AM
1 MEAN Z's Avatar
1 MEAN Z
Yes, in order to build these headlights we would have to order a set of 2006 tail lights and a set of 2005 head lights gut and mold the two together. Surprisingly the cost should be comparable to that of having Clearcorners.com or Cincitydesigns.com supply and build a set of 2006 headlights with every option. Once the other headlight is completed they will be mounted in the Z. From there I can get some pics of them and start on the adjusting of the angle and trying to get a cut off of some type fabricated into them.
Old Aug 20, 2010 | 11:17 AM
BigD2k5's Avatar
BigD2k5
How is the light output on the headlights? Any pictures?
Old Aug 20, 2010 | 04:24 PM
1 MEAN Z's Avatar
1 MEAN Z
I do, all the info you are looking for is at this link.....
https://my350z.com/forum/exterior-an...il-lights.html
Also at...
Let me know if this is what you are looking for.
Old Jan 10, 2011 | 10:38 PM
Bigalow's Avatar
Bigalow
Also at...
This is probably far reaching but is there any way you can make the tail lights look like someone is staring at you like the G37 lights??
If not then I'm interested in another mod. Do I have to supply my own LED tails?
Miguel Albanez
Oct 17, 2022 10:13 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
hardkicks
Sep 20, 2015 12:28 PM
