380RS Pedal Question
I just installed the 380RS accelerator pedal on my '06 Base Z, using the two OEM plastic peices (sold seperately) since the pedal alone will not fit a Base model. After installing, I noticed that the pedal is able to slide to the left and right by about 5 millimeters. I'm pretty confident it's caused by the pedal itself because the plastic clips seem to fit snug with the aluminum rod that the pedal attaches to. Does anyone else have this problem with the pedal fitting loosely?
Also, my accelerator pedal naturally sits back about an inch farther than my clutch and brake pedals. I would think it's easier to heel-toe downshift if it didn't sit back so far. Is the pedal on all the other models sunken in like this also?
Sounds like you may have an issue there. Gas and brake should be about even. It's the clutch pedal that sticks up. When I put pedals in my car, I just drilled holes in the existing stuff.
That was the only way to get them to feel solid.
The brake pedal sits higher because there's some free travel which is taken up when you depress the pedal. My '08 is also a base, and my 380RS pedal is also a bit loose. One these days when I'm not feeling so lazy I'll put a piece of shrink-wrap tubing on the bottom section of the throttle rod, and I think that will build it up enough so the pedal fits tightly. I've also got the OEM metal pedals on the brake and clutch, but I'd be happier if the brake an throttle pedals were closer together. I'm used to my Alfa Spider's, where the brake and throttle are very close.
http://cornerbalance.wordpress.com/2...pedal-install/
Complete install w/ pics.
"For base owners with the factory rubber pedal, if your stock pedal install as per the pics, it will bolt on. If not, you will need the additional clips. "
The solution to your problem is here:
The link is dead, and I do have the "additional clips". The difference seems to be that the base model throttle shaft is just slightly smaller in diameter than the others. As I mentioned, a short section of heat-shrink (or even some tape) should easily solve the issue. Hopefully the OP and I are both talking about the same issue, but I think we are.
The pedal assemblies have a different part number for Base models, all years. Mine doesn't fit perfectly either, just a couple millimeters really, but enough to have a little bit of play.
The bushing provided for the bottom of the pedal is just fine, but the U-section that the throttle shaft fits into is just too small in diameter. I took mine apart tonight, slid on two layers of 1"-long piece of heat-shrink tubing on the section of the shaft that fits into the top part of the pedal, and now it's fine. No free-play, and no noise when I take my foot off the pedal. 5-minute fix, and if you don't have any heat-shrink, several wraps with some electrical tape would work equally well.
So I will have to increase the diameter of the throttle rod for the upper attachment like you did, but I will also have to increase the diameter of the plastic bushing for the lower attachment. I'll take pics as well when I do mine up this weekend.
Hey and check this out. I think I found the blog that guy was talking about: http://cornerbalance.wordpress.com/2...dal-install-2/
Look at the second picture, it looks like they use some clear tubing to widen the diameter of their throttle rod. Although they don't mention anything about it... I wonder if that's a peice we should have?
Nice, that is exactly my problem with the upper attachment as well. However, the second (bottom) attachment is also loose (at least in my case). The end of the throttle rod fits snugly into the plastic bushing, but the plastic bushing does not fit snugly into it's spot in the 380RS pedal.
Word man I got some heat shrink tubing left over from my head unit install. But to sum this thread up... WTF NISSAN? I don't know how they could've messed up such a simple little peice of aluminum but they did
The rubber tubing is probably there to dampen any vibrations that might happen with a metal-to-metal contact. Another easy fix would be to pivot the pedal down, slap on a dab of silicone caulk/gasket sealer on the pedal, and then pivot it back up and snap on the clip.
