console lights out..HELP
Old Feb 12, 2011 | 10:49 AM
silvertouringz's Avatar
silvertouringz
Default console lights out..HELP
Hi all. I have an 04.5 touring w/o nav. 2 days ago i pulled out my bose HU to fix the cd changer ribbon issue and it is fixed now. Now there are 4 harnesses concted to the HU (2 upper, 2 lower). As i was pulling out the HU, the 2 upper harnesses got opened and the wires were all over the place. Now i found a color diagram online and installed the wires accordingly (see colored wire diagram pic below)...everything ran smoothly until it was night. I turned on my headlights and the lights on the HU illumination did not turn on..in other words when i turn on my headlights, nothing changes inside the car. The TSC, Heated seats, HU, and other console lights dont go on. I pulled out the HU again a while ago and checked the wiring..it is just like the pic below and everything seems ok. Also i checked every single fuse in the car and everything was ok..Any help would be really appreciated. thanks
Old Feb 12, 2011 | 11:21 AM
Kuhan's Avatar
Kuhan
You mentioned you checked every fuse, but did you check the fuse blocks in the side panel under the steering wheel?
Old Feb 12, 2011 | 11:42 AM
silvertouringz
i checked the fuse boxes in the battery box under the hood and the one next to the clutch pedal..is there another one? where exactly?
Old Feb 12, 2011 | 01:57 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Does your tach and speedometer work?
Old Feb 12, 2011 | 02:17 PM
silvertouringz
yes they do..everything works except when i turn on my headlights, the dashlights dont come on..
Old Feb 12, 2011 | 03:27 PM
NismoZR's Avatar
NismoZR
Did you check the fuse box behind the battery in another word you would have to remove the battery to access to the main fuse box under the battery not the one in front.
Old Feb 12, 2011 | 04:33 PM
NismoZR's Avatar
NismoZR
Here is the link to the fuse location https://my350z.com/forum/1806090-post2.html.
IPDM E/R
Old Feb 13, 2011 | 01:12 PM
silvertouringz
IPDM E/R
wow no didnt know there were fuses there...should be a blown fuse inside that box...thanks alot nismoZR!
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
