Plasti-Dip Questions & Projects Thread
Old Oct 21, 2011 | 01:56 PM
  #201
Daron's Avatar
Daron
Originally Posted by BSERIEuS
did you guys remove the door handles to plasti dip them?
or tape off the area and paint while its on the car????
No I just taped off the area and then added newspaper around it to catch the overspray. Even if you have a little overspray it comes right off.
Old Oct 21, 2011 | 02:10 PM
  #202
orangeNblue's Avatar
orangeNblue
Default temperature
how well would this stuff work on say an engine cover?
Does it handle higher temperatures well?
Old Oct 21, 2011 | 11:45 PM
  #203
PrimeX's Avatar
PrimeX
Plasti dip is getting out of control.
Old Oct 22, 2011 | 01:44 AM
  #204
KingBaby's Avatar
KingBaby
Hardest Setting
lol.....especially if someone walks up...touches and rubs that **** right off...
Old Oct 22, 2011 | 02:49 AM
  #205
Toby-22's Avatar
Toby-22
well its cheap, and like i said a lot of Z owners are cheap. This to them is considered a mod lol
it can be pulled off if you have nice parts and then plasti dip a few (not every damn trim/badges/handles) things to compliment. But if 90% of your mods consists of plasti dipped this and that, your doing something wrong
Old Oct 22, 2011 | 10:49 AM
  #206
Daron's Avatar
Daron
Always gonna be haters. lol It's their cars so why do you care what they do? It's not a mod, its something that if you don't like it down the road you can peel off and return it to original. That's why I did mine with it.
Old Oct 23, 2011 | 10:43 AM
  #207
moose350z's Avatar
moose350z
Haters are gonna hate.
Plasti-dip is no different than painting any other part on the Z. Its achieving the same results with less costs.
Old Oct 23, 2011 | 11:00 AM
  #208
nismo_nate's Avatar
nismo_nate
i plastic dipped my mountain bike in matte white.. it didn't turn out so well lol.. i ended up removing it lol.. i'll try and snap a quick picture of the remaining white on it. on the plus side, it protected the bike from the usual chips from rocks
Old Nov 14, 2011 | 08:42 AM
  #209
sry110's Avatar
sry110
Finally had some time this past weekend to remove my scratched-up window/mirror/door lock console off the interior of the door and hit it with some black plastidip. I will post pics later tonight if I get the chance. This was my first time using this stuff and here are my observations and thoughts:
1) I did not sand down the existing factory rubberized finish, mostly because Plastidip is touted as not requiring any prep-work other than the surface being clean and dry. I found that the contour of the scratches is visible after two healthy coats of Plastidip spray, although obviously the visibility is diminished due to having uniform color now. If I were to do it over, I would sand down the piece to have even surface finish before spraying.
2) As I mentioned, I did two healthy coats allowing the first to dry for at least an hour before applying the second. Adhesion seems to be good, but the texture is odd. It almost feels "gritty", or maybe more "tacky" when compared to the OEM rubberized finish. I would say it definitely has more surface texture than the OEM finish.
3) The appearance of the finished product looked pretty good to me, but I have only seen it in the artificial light of my basement and garage, so I'll have to see what I think when I get it outside with sunlight shining on it. In any case, it looks a lot better than a bunch of white scratches all over the place.
Old Nov 14, 2011 | 04:54 PM
  #210
mr. sparco's Avatar
mr. sparco
Originally Posted by sry110
1) I found that the contour of the scratches is visible after two healthy coats of Plastidip spray
2) It almost feels "gritty", or maybe more "tacky" when compared to the OEM rubberized finish. I would say it definitely has more surface texture than the OEM finish.
Post some pics.... If you don't intend on ever taking it off, then sand and prep to get rid of imperfections.
The way it is applied, meaning your spray pattern will affect the outcome of the overall surface feel. If you mist it on at the right distance, time interval and amount it will come out pretty smooth.
Helps to have some body work experience.
Old Nov 14, 2011 | 05:21 PM
  #211
Spork's Avatar
Spork
This trend needs to die.
Old Nov 16, 2011 | 06:28 AM
  #212
sry110's Avatar
sry110
At the expense of getting defensive, I can only partially agree with your sentiment. Would I cover my front bumper with it? No. Would I repaint my interior rubberized door handles in lieu of paying Nissan $exorbitance to replace them? Yes.
Old Nov 16, 2011 | 07:45 AM
  #213
slo_latino's Avatar
slo_latino
the Nissan emblems will be dipped this weekend. that is all.
Old Jun 13, 2012 | 12:39 PM
  #214
yogipower's Avatar
yogipower
you did really well on your Z (: speically 350z emblem on the back.
Old Jun 15, 2012 | 03:21 AM
  #215
endless_summers's Avatar
endless_summers
I have a couple of pics I snapped when i was doing my dipping. It has been a couple weeks and has held up very well!
And this is the final results along with my OD Green plastidipped wheels
Old Jun 15, 2012 | 07:47 AM
  #216
STL 350Z's Avatar
STL 350Z
How do you take it off the paint around the emblem and handles?
Old Jun 15, 2012 | 10:40 AM
  #217
endless_summers
It's similar to vinyl. It just peels off. Go to youtube and search "plasti dip your car" and "plasti dip removal". There's a company that bundles a couple gallons of the dip and some thinner and a spray gun to do your whole car but I don't think I can mention who they are if they aren't a site supporter/vendor. Some googling will give you results though.
<iframe width="420" height="315" src="http://www.youtube.com/embed/m5H69eMjUXk" frameborder="0" allowfullscreen></iframe>
Old Jul 3, 2012 | 06:04 AM
  #218
skeetz9r's Avatar
skeetz9r
Default So I decided to Dip car parts in plasti
Dip it in some plasti.
Did the emblems, side mirrors and rims** , I didn't want to over do it. Initially I just wanted to see how black tires would look on the ride.
I think I'm kind of in love already.
Front set done.
Old Jul 3, 2012 | 06:36 AM
  #219
ZS14RR's Avatar
ZS14RR
Need more pics. The one and only you posted sucks.
Old Jul 3, 2012 | 06:57 AM
  #220
big_dish's Avatar
big_dish
Tires are already black, no?
