Headlight Questions..
Old Jul 16, 2011 | 04:55 PM
Debid.Oppa's Avatar
Debid.Oppa
Red face Headlight Questions..
Hey guys, Im new to the forums and recently bought 04 ppw 350z. Im new to this so no bashing please.
I recently bought a new pair of headlights because the orignal ones seemed to have a crack and fogged up. The question i wanted to ask is.. do I need to buy a new set of HID BULBS or do i need to also get the whole HID kit? Either way im planning to get 6k or 8k bulbs for the headlights.
(Not to sure if Z's come stock HID's)
Help is most appreciated!!
Old Jul 16, 2011 | 05:10 PM
brocw1093's Avatar
brocw1093
What trim of a z do you have? I have a touring ( has leather Bose system ect) and this comes with stock hids. Other models of 350z's didn't. If you have one equipped with stock hids you have to buy hid oem headlights, or like I did buy a pair of non- hid headlights heat them up in the oven and ur original ones and replace the plastic lens, it's a lot of work but saves you a lot of money. If money doesn't matter buy oem ones.
Old Jul 16, 2011 | 05:14 PM
Debid.Oppa's Avatar
Debid.Oppa
I have the track model. Couldnt I just buy HID kit and just connect it to my stock headlights?
Old Jul 16, 2011 | 05:18 PM
Debid.Oppa's Avatar
Debid.Oppa
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W This is what im referring to. Just buying the HID kit.
Old Jul 16, 2011 | 05:27 PM
CTZ860's Avatar
CTZ860
You should just be able to get away w/new bulbs which are pretty pricey too but better than a whole kit.
What year is your Z?
Old Jul 16, 2011 | 05:39 PM
Debid.Oppa's Avatar
Debid.Oppa
its a ppw 2004 350z track model.. So i just need new bulbs and i should be good to go? i dunno if like 50 bucks is being too pricy lol. but i listed the website below.
Old Jul 16, 2011 | 05:42 PM
Bulbs do not determine if headlights are HID or not. HID is generally a xenon bulb with ballasts. Its a system. You cannot simply swap bulbs to make no-HID to HID.
Old Jul 16, 2011 | 05:45 PM
Debid.Oppa's Avatar
Debid.Oppa
So that means I need to get the HID kit? lol
Old Jul 16, 2011 | 05:52 PM
The OEM headlights are HID. If you are uncertain remove the bulb. Post photos here.
Old Jul 16, 2011 | 06:02 PM
Debid.Oppa's Avatar
Debid.Oppa
THanks for all the help
Old Jul 17, 2011 | 08:32 AM
gregom's Avatar
gregom
Your track model came with HID from the factory. All 04-05's came with HID unless they were base model. I'm surprised davidv didn't grill you for this...
Anyway, what replacement headlamps did you buy? OEM or aftermarket? Can you show us? Are they HID or halogen?
If they are HID, you can simply swap your old stuff over to it no problem. You can move to some higher color temp HID bulbs as well. However the stock color is the brightest, going higher to 6000K or 8000K will get more color but be more dim. They must be D2R or D2S socket type. Get D2R if they have them, if not the D2S will work but you'll have to cut a little notch in the plastic base of the bulb so it will fit in your headlamp projector.
Old Jul 17, 2011 | 11:38 AM
Debid.Oppa's Avatar
Debid.Oppa
The headlights I just bought are the same besides the blackening on some areas on the housing. <a target='_blank' href='http://imageshack.us/photo/my-images/824/imag04111.jpg/'><img src='http://img824.imageshack.us/img824/7452/imag04111.th.jpg' border='0'/></a>
Uploaded with <a target='_blank' href='http://imageshack.us'>ImageShack.us</a>
Im hoping these headlights are just a simple swap i can do with new bulbs. (8000k). Is ther a way you can tell me just from the picture if I will need to do anything else inorder for these to work on my Z?
Old Jul 17, 2011 | 07:22 PM
Not certain what you bought. Look at the socket. It either accepts a xenon bulb or it does not.
Old Jul 19, 2011 | 03:50 PM
gregom's Avatar
gregom
Where did you buy the headlamps from? Is there a web page with specs we can look at? We can't tell anything just from a pic of the outside... If these are HID and you have stock HID ballasts, then yes you can just swap to 8000K D2R HID bulbs. However I would not recommend over 6000K, especially as the 03-05 headlamp design does not really yield good output compared to a true projector headlamp. With 8000K you'll be putting about as much light on the road as the rusty old dodge caravan driving next to you.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
