03-05 with 06 Headlights (Blinker Light Modification)
Old Mar 23, 2012 | 04:11 PM
Mr. Nibiru's Avatar
Mr. Nibiru
Default 03-05 with 06 Headlights (Blinker Light Modification)
So does anyone know how to fix the fact that when you put on 06 headlights on an 03-05 why the amber blinker stays on when the headlights are on?
http://www.cardomain.com/ride/322516...0z#32251640012
Noticed it on my 03 and it's the same on my 05. Thanks.
Old Mar 23, 2012 | 05:35 PM
bmccann101's Avatar
bmccann101
03-05 turn has 2 wires, 06 and up has three, not sure which, but cut and terminate ( seal one.
You can test w a volt meter which is the one thats on all the time. Some ppl say just to bend a pin back in a harness, not sure where thats at tho or what thats about.
wire thing woirks fine tho
Old Mar 23, 2012 | 09:57 PM
Waiz's Avatar
Waiz
There are plenty of threads on this if you search.
This is one of the most comprehensive that I found by doing a search right now:
https://my350z.com/forum/exterior-an...ease-help.html
Old Mar 23, 2012 | 10:56 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
This is new to me. I thought it was a "plug-n-play" as well.
Old Mar 24, 2012 | 04:24 AM
cgkp0925's Avatar
cgkp0925
It definitely has been covered plenty of times.
I recently just did it on my '03 with 06+ headlights. The blue wire is the one you have to cut off the signal to, but I didn't cut any wires. I just looked inside the headlight bulb socket and looked to see where the blue wire was connected inside the socket. I then placed a small piece of electrical tape on the corresponding bulb prong that would make contact with the blue wire inside the socket. I did this only if for some reason I had to replace the headlights in the future, and maybe someone else could use it on an 06+ model.
Pretty simple, if you don't want them on all the time.
Old Mar 24, 2012 | 01:14 PM
kevincat's Avatar
kevincat
just cut the blue wire and tape the ends. if the time come to sell then just solder the blue wire back together. SIMPLE!
Old Mar 24, 2012 | 05:27 PM
shaddy-z.'s Avatar
shaddy-z.
I didn't even know there was something wrong I thought it was normal haha. Oh well, seems kind of tedious work that I don't really have the urge to do.
Old Apr 4, 2012 | 10:36 PM
Mr. Nibiru's Avatar
Mr. Nibiru
Default Thanks
Thanks for the info guys.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
