Need 'Silver Turn Signal Bulbs'? Look Here!!!
Old Jan 17, 2004 | 11:02 AM
TXSTYLE's Avatar
TXSTYLE
Question Where To Get 'Silver Turn Signal Bulbs'?
Not cheaply painted on, but QUALITY bulbs i.e. Phillips or Sylvania.
Something like these:
Old Jan 17, 2004 | 01:50 PM
toykilla's Avatar
toykilla
i would like to know also
Old Jan 17, 2004 | 03:38 PM
FLY BY Z's Avatar
FLY BY Z
Me too. I saw a Z the other day turning left in front of me and his turn signal was clear/silver and it was REALLY bright. I want that.
Old Jan 17, 2004 | 03:52 PM
ares's Avatar
ares
Veteran
from what I understand only APC makes them in 7440 size you need.
Old Jan 17, 2004 | 07:16 PM
sbonell's Avatar
sbonell
You certainly can't those Phillips ones in a Z fitting. At least not in the UK.
Anyone have a URL for APC?
Thanks
Stuart
Old Jan 17, 2004 | 10:02 PM
alphared's Avatar
alphared
you can get some on ebay for about 12 bux a pair. I got a pair (not APC) and it wasn't paint. Its pretty nice, and if it does fade or chip, I can always get another.
Old Jan 17, 2004 | 10:28 PM
FLY BY Z's Avatar
FLY BY Z
I did a search on Froogle.com and found a site that had PIAA 7440 and 194/168 both in Xtreme White. I bought them for $27 shipped for both pairs. I have no idea if this is a good price and don't really care. It is fair enough considering I don't have to go to Pep Boys.
Old Jan 17, 2004 | 11:33 PM
350zluvr's Avatar
350zluvr
Default 350z silver turn signal bulbs
Go to ebay and search "350Z turn". That brought me to pro street lighting's silver turn signal bulbs which run $15.99. They are not painted, but rather the glass itself is silver.
I just received mine and installed them today. IMO they look great and work great. It looks completely silver (w/ no hint of amber), but lights up amber. I think they make the entire front lighting cluster seem more integrated and smooth. I would also suggest getting some for the rear turn signal as that one also seems amber and might gain an advantage at having all four turn signals match (2 rear and2 front).
With my experience the shipping took a little bit longer than expected. I paid on 1-7-04 and it was shipped out 1-12-04 then I received them 1-17-04.
In case this post is viewed shortly here is the link: 350Z turn signal bulbs on ebay
Old Jan 18, 2004 | 12:07 AM
mgl's Avatar
mgl
just a small warning.....
i got a set of the silver bulbs that light up amber off ebay. i put them in and they looked great. i really like them a lot, but a few months after the bulbs were in i noticed that the silver housing above the turn signal bulb was getting dull. i think the bulbs burned at a higher temperature that caused the housing to heat up more than it was supposed to. i immediately took them out, but the damage was done.
Old Jan 18, 2004 | 10:54 AM
TXSTYLE's Avatar
TXSTYLE
Thanks ALL for the suggestion.
And thanks MGL for that honest take on what happened.
That's EXACTLY what I'm trying to avoid.
We all know what a pain in the **** it is just to install bulbs in our cars, so when I do it....... I want it to last!
Now then...... For all you guys that have actually done this, can you do me a favor an grab the "stock bulb" and tell me the:
Any & Everything the amber stock BULB says on there? I mean numbers, letters, words, etc.
Thanks, TX
Old Jan 18, 2004 | 11:35 AM
ares's Avatar
ares
Veteran
the lighting in the room is lacking; so might have a letter wrong here and there
(E4)21*then2 characters that I dont recognize*
WY21W 12V
KOITO JAPAN 2-6M4
Old Jan 18, 2004 | 01:18 PM
mgl's Avatar
mgl
Thanks, TX
no problem.
if you ever find out what kind of bulb is safe for the housing please let me know...... i really like the look of the silver bulb.
good luck.
Old Jan 18, 2004 | 02:05 PM
350zluvr's Avatar
350zluvr
mgl, did you ever have the lights blinking for an abnormal amount of time when you tried out those silver bulbs? In everday normal use I just don't see how a blinking bulb can have enough operation time to heat up to those extreme temps.
Also mgl, do you by chance remember the sellers name that sold you the silver bulbs?
Old Jan 18, 2004 | 03:00 PM
ares's Avatar
ares
Veteran
grab onto a bulb sometime, they can hit full temp in about 15sec, and dont dissipate it nearly as fast. I clocked the parking light bulb at 260degrees. thats only 5 watts.
Old Jan 19, 2004 | 12:28 AM
sbonell's Avatar
sbonell
Wow - that puts a different spin on it Ares.
Possibly the silver coating oxidising and that settling on the reflector (rather than the heat damaging the reflector).
Just speculating.
Stuart
Old Jan 19, 2004 | 08:18 AM
ares's Avatar
ares
Veteran
its possible. I thought Id heard of someone else describing the same problem. might have been you, MGL. didnt think it was though.
could just be the metal is transfering heat better, so it does dissipate it faster, and thats the problem...
Old Jan 19, 2004 | 09:43 AM
350zluvr's Avatar
350zluvr
The silver turn signals bulbs I bought run at 8/27W. Is that the same as stock or is that hotter, colder, anyone know?
Old Jan 19, 2004 | 10:00 AM
sbonell's Avatar
sbonell
Turn bulbs are 21W as standard in the UK. Not sure over there.
Cheers
Stuart
Old Jan 19, 2004 | 10:28 AM
ares's Avatar
ares
Veteran
yes, the turn signals here too are 21w. brake light is 5/21 watt. might be a source of trouble.
Old Jan 19, 2004 | 11:18 AM
350zluvr's Avatar
350zluvr
Well that's not very good
If anybody knows of a Silver turn signal bulb that runs at stock wattage please let us know. I just found out I need a replacement... bad!
