the "bmccann101s car gets a new look/ watch me suffer bodywork hell" thread
Old Nov 24, 2014 | 10:54 AM
  #721
bmccann101's Avatar
bmccann101
so these fat tires dont fit so hot out back.. just doesnt give the right look tbh.
kind of sucks tbh. the wheel has to sit in too far, and then it disappears under the flare as soon as it airs out..
Too soon to tell exactly. car should be done soon tho.
Old Nov 24, 2014 | 11:04 AM
  #722
KingBaby's Avatar
KingBaby
Hardest Setting
Align it at its lowest height ?
  #723
isy_nismo's Avatar
isy_nismo
Do you still using the VIS hood?
Old Nov 24, 2014 | 11:05 AM
  #724
Nismo350z#0310's Avatar
Nismo350z#0310
damn, thats a bummer. Maybe spacers? I know that will just increase weight though. It'll fix the look though.
Old Nov 24, 2014 | 12:15 PM
  #725
bmccann101's Avatar
bmccann101
it already had spacers.. the issue is that the edge of the wheel/tire passes by the fedner lip in an arc.. when its higher up.. the wheel and tire edge is below and outside the fender flare.. as it lowers.. it comes closer in to the lip as it also moves up.. and at the last moment as it lays out.. the tops camber way in and disappear into the flares.
if it just stopped at the flare thatd be fine.. but either the tire needs to be less tall and be able to clear the lip easier as it moves... or the whole wheel needs to be cambered in more.. spacers are being used of course.. but they have to keep being swapped out for different sizes as we play w it.. and as for now.. thats not being worked on really.. 295 square might help spove some issues as well.. i always turn tcs off anyways as a habit when i get into the car.
plenty of body work to do.. ill get the wheel and tire thing figured out.. theres only so much that can be done, so im not concerned about " what do i do" in regards to that.. it just is what it is and we shall see when its that time really.
Old Nov 24, 2014 | 12:16 PM
  #726
bmccann101's Avatar
bmccann101
yes they are trimming the JUN hood to fit for me.. and i also ordered a 2nd hood, the Varis version.. but that wont be here until January.
Old Nov 24, 2014 | 03:14 PM
  #727
KingBaby's Avatar
KingBaby
Hardest Setting
If I did a cup kit/bags I would setup the car up to how I want it i.e. Lowered then have the system naturally raise it.
So when "aired out" bring the camber back to zero as much to get the flush look with/without spacers. Then let do its own thing when you raise is slightly for bumps. I don't see you raising it all the way up ever? The bags is just to get over obstacles, correct?
Old Nov 25, 2014 | 03:28 AM
  #728
isy_nismo's Avatar
isy_nismo
If you finally use the varis version let me know.. I'll be interés red in the JUN one if you decide to sell it..
Amazing proggress!!
Old Nov 25, 2014 | 07:29 AM
  #729
bmccann101's Avatar
bmccann101
yeah the JUN hood is getting cut up pretty well, no point in selling it tbh.
so my z missed HIN this year, so i brought my daily.. and i friken won.
Pretty stoked about that.
in other news, the Z is going to use the JP bumper after all.. we tried it out last night and it is stellar.. far better than the Do Luck.. shorter, more aggressive. Squares teh car out.
my body guy was stuck at the shop waiting to get a ride home from the gf so he popped a few beers and started messing w louver design lol.. all in good fun.
In the end wed do it much more like this one if anything.. or perhaps use a metal version off a mustang and just cut n weld it to fit. Might fit the car in the end.. might not.. but you know i wont do it if its not legit.
Old Nov 25, 2014 | 09:23 AM
  #730
Nismo350z#0310
I hope you come to shows on the East coast. i want to see this thing in person when its completed
Old Nov 25, 2014 | 09:26 AM
  #731
mr. sparco's Avatar
mr. sparco
I like it with the JPz front.
Old Nov 25, 2014 | 09:43 AM
  #732
Nismo350z#0310
+1 JP front looks good
Old Nov 25, 2014 | 10:00 AM
  #733
vex008's Avatar
vex008
i do like the JP as well as the doluck.
question now is....whats the plan with the doluck front
Old Nov 25, 2014 | 10:01 AM
  #734
bmccann101's Avatar
bmccann101
yeah the jp fropnt is much shorter than the Dluk.. which makes teh back appear longer.. jsut makes for a better looking profil eimo.. plus i can go crazy w "Salvador dali moustache Canards" w this one and have it line right up past the side openings.
Old Nov 25, 2014 | 10:02 AM
  #735
bmccann101's Avatar
bmccann101
already had some bodywork done to it, so its not easily resellable to anyone else tbh.. ill just keep it as a spare for when i want a cahnge of pace/look.. i added nutserts to everything on the car, so no more plastic caps etc.. makes swapping things around very easy.
Old Nov 25, 2014 | 10:05 AM
  #736
vex008's Avatar
vex008
OK. FYI they make a louvers for the FRS/BRZ/86 thingy. might be worth looking into
Old Nov 25, 2014 | 10:13 AM
  #737
bmccann101's Avatar
bmccann101
nice.. i found a z that has metal ones modified as well.. awaiting his IG add from my request tho.. hope to find out more soon.
Old Nov 29, 2014 | 03:34 PM
  #738
bmccann101's Avatar
bmccann101
first things first:
EPIC frikn PAWG.
Drew up the front splitter.. wheel width.. going to need to pick out some canards soon.
reshaping the flares trailing edge curve so it matches the square of the fender.
ditched the chicken wire.. went with gloss black powder coated thick gauge aluimoinum mesh.
Old Nov 29, 2014 | 07:08 PM
  #739
mr. sparco's Avatar
mr. sparco
Staying matte black or going for a new color?
Old Dec 1, 2014 | 12:28 PM
  #740
bmccann101's Avatar
bmccann101
oh god no.. new color for sure.
