TS Diffuser and Agency Power
So today i placed an order on Agency Power exhaust, and my next buy was TS Diffuser, but i read that it doesn't fit, my question is, does anybody here know if with some small cutting will allow the exhaust to fit?
then why not post in that thread vs making a new one? The next guy that has an agency power may go to that thread looking for the same answer which may be in a different location.
With the size of the can on that exhaust it would be a lot of trimming to do and more than I would recommend probably. I trimmed mine for the HKS but only had to do part of the read flap and leading edge.
Best buy is to find someone local who has one and try to test fit or to buy and test fit and resell if it doesnt. You may lose like $50 but that is the name of the game.
What area actually needs to be trimmed on the diffuser?
Being CF,this is not something thst can be refinished like FG,
If the trimming involves a cutting a edge,I've used black edge
guard material like used for door edge protection.It blends with the
CF and has an adhesive.
the issue is the agency power can will likely protrude from the bottom so a lot of the lower material will be trimmed, weakening the diffuser since the leading edge flap will also be trimmed.
Placing order next week when i get my pay check
good. Just an fyi, if you have not relocated your evap canister (most havent) then your bracket on the passenger side will most likely not work. You may need to make one out of aluminum.
hard to believe no one in the chicago area has one. They were very common addons.
Hell i had an authentic front and replica rear for a while.
And in the 3 years of going to car meets in Chicago area, i haven't seen a single TS Diffuser. Maybe i just didn't see it, but how do you not spot that diffuser!
