Head unit compatability
Old Jul 28, 2017 | 06:18 PM
SKYLAR's Avatar
SKYLAR
Default Head unit compatability
Can a 2006 bose head unit plug and play replace a 2005 bose unit? Thanks
Old Jul 28, 2017 | 11:15 PM
DarkZ03's Avatar
DarkZ03
No, waterfall is different.
Old Jul 28, 2017 | 11:51 PM
dcains's Avatar
dcains
It's not just that - they're not compatible electronically, either.
Old Jul 29, 2017 | 10:15 AM
SKYLAR's Avatar
SKYLAR
Default confused
Thanks for the responses...but I'm now more confused...:-)
First, what is a waterfall, in reference to the Bose Radio's and second, a Nissan tech told me they should interchange, as the plugging arrangement is identical on both units and the only difference in functionality is the lack of a cassette player in the '06....
I'm not questioning your responses I'm just not sure what they mean....given I went to two separate dealers, asking both the service dept's and parts departments about interchangability; no one seemed to have a definitive answer, and they had no suggestions on how to get an answer...which is why I asked here.
Old Jul 29, 2017 | 01:30 PM
dcains's Avatar
dcains
Apologies, I actually mis-read your first post as one being Bose and the other not Bose. Thus, I have no further info to offer.
Old Jul 29, 2017 | 03:18 PM
beezee's Avatar
beezee
Waterfall is the upper dash that houses the headunit and the triple gauges. The reason they are not interchangeable is that the opening for the radio is different between the years. That's the reason why the dash kits are different if you are installing an aftermarket radio. I wonder why the dealership could not confirm that.
Old Jul 30, 2017 | 12:34 PM
DarkZ03's Avatar
DarkZ03
It's plug and play if you replace the everything else to the newer style (I did) why are you asking anyway?
Old Jul 30, 2017 | 01:40 PM
SKYLAR's Avatar
SKYLAR
The physical specifications are identical for the 2005 Bose radio and the 2006 Bose radio so I can't see where the "waterfall" would have any impact....I asking because I just want to get rid of the 2005 Bose and it's worthless cassette player,,,(the 6 cd changer is screwed as well) and I have an opportunity to get a 2006 Bose for not much. Eventually I'll upgrade but I haven't seen anything that's that appealing, so i'd use the 2006 Bose as a placeholder for now...
Old Jul 30, 2017 | 07:38 PM
beezee's Avatar
beezee
Well if you are certain that the physical specifications are identical go ahead and swap then. At least someone confirmed the wiring for you. Just report back to prove us wrong on the waterfall. I have played with that before and ended up with gaps but maybe I did something wrong
Old Jul 31, 2017 | 04:05 AM
SKYLAR's Avatar
SKYLAR
will do....
Old Jul 31, 2017 | 01:57 PM
DarkZ03's Avatar
DarkZ03
I figured that's what was going on, they mount lower, use different brackets and are a different shape. Out of all people I could tell you the 100% truth since I've done the swap the the new style interior twice....
Old Jul 31, 2017 | 07:22 PM
SKYLAR's Avatar
SKYLAR
thanks Dark,
I appreciate your experience and response...it does appear that while the plugs are similar,,as is the wiring schematic, with the exception of the steering wheel circuit, the lower corners of the 2006 Bose are rounded, verses the squared off corners of the 2005 Bose....my final confirmation will be checking the nissan part numbers of the bezel(s)....(which probably should have been my first point of inquiry)..:-/
Old Aug 4, 2017 | 02:47 PM
mcubed45's Avatar
mcubed45
Different
https://www1.crutchfield.com/shopsearch/350z.html
Rybear458
Audio Video
Feb 2, 2017 10:51 AM
TylerHighRoller
Dec 10, 2016 11:41 AM
Key Mucciante
Dec 1, 2016 01:12 AM
dboyzalter
Nov 14, 2016 05:25 PM
superkatt
Audio Video
Oct 21, 2016 06:03 AM
