Widebody: Welding or Panel Bonding?
Old Nov 12, 2018 | 01:46 PM
Blackskiies's Avatar
Blackskiies
Exclamation Widebody: Welding or Panel Bonding?
I am having overfenders put on, so I cut the rear quarterpanels and now the tabs from the inner layer are folding out over the outer layer nicely.
So i see that a lot of people have it welded but this shop highly suggested that i use something called panel bond to reattach the two layers.
Has anyone done it this way before? The shop said they will still weld it for me if i insist, for $600, but if they are a body shop, wouldn't they be money hungry and want to weld it for me instead of suggesting panel bond which is something relatively inexpensive compared to having it welded? He told me specifically how to do and step by step and also where i can purchase it. I find this very mind boggling.
Is he being honest and helpful? or is there something suspicious going on? PLEASE HELP
Old Nov 12, 2018 | 02:03 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
3M Panel Bond is used by a lot of pro shops and is a perfectly acceptable solution for what you're doing SO LONG AS it's applied properly with no gaps or scrape off for corrosion to get in. Also good to use a rust inhibitor (usually aerosol) between the panels prior to sealing. I've watched my body shop guys use it and it's legit. If you were attaching a full quarter panel, there are areas that REQUIRE welding (usually fore/aft/top attachment edges where connecting to body work) but between the liner and shell, not necessary.
Old Nov 13, 2018 | 06:50 AM
Blackskiies
I also saw this video by siegestyle where he riveted the two layers together.
I was pretty set on panel bonding but should i rivet it instead?
Old Nov 13, 2018 | 06:59 AM
MicVelo's Avatar
https://www.youtube.com/watch?v=eWTeJViwFus
I wouldn't. That leaves gaps, however small, to allow in moisture and dirt. Pretty soon you'll need to replace metal work. The panel bond seals the gap (and edges( when done right. (Or so I was told by my body shop manager, when I first saw it being used and asked. I am NOT a body man by any stretch of the wild imagination.)
I also wouldn't want any extra metal pieces extruding that could possibly come in contact with the tire, especially with a big tire setup that close to the edge.
Old Nov 16, 2018 | 05:26 AM
Blackskiies
Panel bonding seems legit.
Fell onto this blog and thought it might help some of yall (especially yall diy peeps) out there
Fellow Z brudda didn't weld, but used panel bond to hold it up:
https://conceptzperformance.com/blog...-installation/
Im utilizing the shortened daylight time i have to finish this widebody before the brutal winter comes, but i will try to take pics.
Stay safe bruddas
Old Nov 16, 2018 | 01:31 PM
Spike100's Avatar
Spike100
Subscribing...
Old Nov 19, 2018 | 08:46 AM
Blackskiies
Test Fit BattleAero rear overfenders
Slotted tabs #cleancuts
Old Dec 24, 2020 | 03:01 AM
a0am1ner4la's Avatar
a0am1ner4la
If you want to weld, then you must be fully prepared and have not only physical strength but also equipment. Equipment is the most important thing in welding and even if you know how to weld, and you have a lot of experience, then without equipment you will not be able to weld anything normally. The welding table has always been the main part of the equipment, and it is not so easy to find a normal table at a good price in our time. But in order not to waste a lot of time and money, you can go to the site https://afterpaints.com/best-welding-table-reviews/ where they will explain and show you the best tables and where you can buy them.
Vicarious
Feb 10, 2005 04:49 PM
Justin
Dec 8, 2003 03:37 PM
redfox
May 26, 2003 06:34 AM
