Falcata Re Body my Zed
Old Sep 29, 2020 | 07:18 AM
  #41
fast720's Avatar
fast720
Default Falcata
Originally Posted by iideadeyeii
Dude, shut up. This is coming out sick. Have you seen the pictures of the "porsche 350z" ?
Hi I haven't seen the Porsche 350Z until now , thanks for mentioning it me , it's alright !!
Old Sep 29, 2020 | 07:28 AM
  #42
fast720's Avatar
fast720
Back to the front fenders .
Old Sep 29, 2020 | 08:13 AM
  #43
iideadeyeii's Avatar
iideadeyeii
Someone said earlier about the aggressiveness of the car/added weight. Any plans for forced induction or any type of power adders? Or is this for show only?
Old Sep 29, 2020 | 08:57 AM
  #44
fast720's Avatar
fast720
Default Falcata
Hi the car will likely be lighter , what you see in these pics are the plugs being made , there will be molds taken from these fenders , doors , hoods , etc. all the parts will be made of fiberglass and vacuumed bagged to make the lightest strongest parts possible , all the stuff you see now on the car is just being used to make the shape , unfortunately all of this goes in the garbage after .......a ton of money and so far two years of full time work .
Just deleting the rear hatch alone will save a ton of weight !!!
This first car will be a daily driver , all stock and reliable , I will build another one that will be ***** to the wall track street car , no interior full cage , LS3 with a blower .
It will be called Falcata Beast
Thanks for your interest .
Old Sep 29, 2020 | 10:43 AM
  #45
iideadeyeii
ummm, DON'T THROW THAT AWAY
  #46
iideadeyeii
Or rather, nvm. I understand. You are going to make molds and the foam and stuff will be thrown away
Old Sep 29, 2020 | 10:45 AM
  #47
iideadeyeii
My CF hood weights about 1-2lbs heavier than my stock hood. The hatch is pretty heavy. This is great stuff and I never though about some of the tactics you are using (Your leveling on the front) I'm more of a "wing it".
Get a 12lb battery and just go for weight savings! I like it
Old Oct 1, 2020 | 07:11 PM
  #48
Row2K's Avatar
Row2K
incredibly impressive. Keep up the good work
Old Oct 5, 2020 | 07:26 AM
  #49
fast720's Avatar
fast720
Thanks for all the great feedback it helps to keep motivated , especially when thing don't go according to plan .
Had a big problem with the trunk , I had it all prepped to make a copy of the trunk bottom and the surrounding area so I could build it off the car .
The car is so wide it's back breaking to work hanging over the side .
Waxed and prepping for the mold release PVA
Spraying the pva
I was on my third layer of fiberglass and for some unknown reason the top layer started kicking off before the bottom and I had no time to steel roll the air out and had to tear it all off and toss it out ................not happy So this is what I had to deal with little glass hairs left on the surface.
So I cleaned up the mess and re-fiber glassed it . This is getting it off the car .
Old Oct 5, 2020 | 07:37 AM
  #50
fast720's Avatar
fast720
Default Falcata
More on the trunk lid
As you can see here it tore off all the slats
Melted the foam
broke the back part where the trunk ends
it was a big mess , the slats were embedded in the part by resin getting underneath them
Man the part was pretty rough , very disappointing , nothing a weeks worth of body working won't Fix
Old Oct 5, 2020 | 10:29 AM
  #51
Heel Til I Die's Avatar
Heel Til I Die
Setbacks are inevitable but I'm glad you're staying with it! That rear section should turn out nice.
Old Oct 5, 2020 | 11:04 AM
  #52
iideadeyeii
Working with fiberglass doing custom work you are bound to have some sort of issue. I copied a whole hood once, it got rained on and never hardened
Old Oct 8, 2020 | 05:49 PM
  #53
Russell Li's Avatar
Russell Li
WOW... Havent even seen the final product but amazing job and the craftmanship. Anyone who will you a hard time they don't know how much you've put in. Keep up the great work and looking forward to more posts.
Old Oct 14, 2020 | 05:02 PM
  #54
fast720's Avatar
fast720
Hi
A little more on the trunk area . after tons of bodywork to rescue the part , it's now been primed and painted , it's not perfect but it's really just a copy of the back of the trunk area so I can work on the trunk off the car . so now i will mold release this and make a fiberglass part to represent the back of the car at the proper angle so I can start building the top louvered part of the trunk .
here it is in primer
a couple of coats of white paint
trunk area copy .
Old Oct 14, 2020 | 08:43 PM
  #55
fast720's Avatar
fast720
I ended up building a base to hole the part , because it was flexing while I was sanding and I was having trouble keeping the surface flat
Old Nov 24, 2020 | 07:28 AM
  #56
fast720's Avatar
fast720
Hi
Been busy with life etc, and building a saw to cut foam , this should help speed things up , the foam is polyurethane and i can fiberglass right over it .
Here is a link
So stay tuned !!!! for more Falcata build !!!
Old Nov 24, 2020 | 02:38 PM
  #57
MicVelo's Avatar
350Z/370Z Tech Moderator
Pretty sure I said it early in the thread but if not....
THIS is a BUILD. So great to see craftsmanship that easily outdoes most of the crap stuff on the Motor Trend channel! Can’t wait to see final product but.... enjoying watching it take shape!
One of just a few threads here that keep me coming back! 👍
Old Dec 12, 2020 | 08:39 AM
  #58
fast720's Avatar
fast720
Default Falcata Rebody
Hi sorry for the delay in the posts , life get's in the way sometimes , and by the end of the day there's no steam left to post stuff .
Started using the new foam , its going to help a lot , I can cut the foam with the new saw I built and then run it through the thickness planer to what ever thickness I need .
Here you can see how malleable it is when thinner .
Here you see the foam cut down to a flexible thickness
This is the thickness planner , I built a dust collector attachment for it
This is how flexible the foam can be !!!
started to build the tail light tray , in the new foam , I had the one made in the blue foam to bust up and trace out.
Old Dec 12, 2020 | 09:04 AM
  #59
fast720's Avatar
fast720
First of all thanks for the super kind words MicVelo it really helps to keep the inspiration going , it's been two years in now , my wife is an angel putting up with me being gone 7 days a week to the shop, and she's been picking up the slack doing my chores at home .
Previous to the new foam , I was working on the replica of the trunk area of the car to be able to work on it off the car .
So lets jump back to that .
If you remember I had a hassle with the glass going off way too soon and had a bunch of bodywork to do before making the copy.
So this is the piece I had trouble with
this is it now fiberglassed to replicate the trunk area in actual size , so I can build the trunk lid off the car
this is abase to hold the part so I can work on it at the right angle so the lid louvers are right .
here are the two parts still together
separating the two
here is the replica , needs to be trimmed
here you can get the idea of why i did this , the car is just too wide to be working on the middle .
the trunk area ready for trimming
Trimmed and ready to start making patterns for the trunk lid
Old Dec 12, 2020 | 11:19 AM
  #60
MicVelo's Avatar
And here I go again..... this blows my mind!
I'm not a super custom kinda driver/owner myself but, to see the work that goes into building the Falcata, well, as I said, this is a labor of love and talent.
I mean c'mon, even that wooden base to hold up the rear decklid, heck, I have trouble building an incline ramp for my mother in law! And your piece has those cutouts to sit over the "bumps"! Who thinks of these things?
Back in the day (70s, 80s) the most "famous" custom street Z was this one, called the PrimaDonna Z...
Pretty radical stuff. But, I'm very glad to see that the custom work lives on and is exceeded!! The Kindig crew is probably the most "custom" of all the builders on TV. Wanna do a series on the build of Falcata MeanMosheen (or whatever the "race version" is called.) Haha.
