350z/z33 tend to understeer
Old Jun 14, 2004 | 10:47 AM
GY-Z's Avatar
GY-Z
Default 350z/z33 tend to understeer
have been wondering alone why our z tends to understeer?
which part of the design in the car makes the understeer?
Old Jun 14, 2004 | 01:32 PM
samw1978's Avatar
samw1978
weight distribution + whole suspesion setup
Old Jun 14, 2004 | 01:56 PM
BulletproofRich's Avatar
BulletproofRich
Most cars are set up to understeer from the factory - much safer for drivers in the event the limits are broken. The weight, weight distribution, Engine position, and relatively soft suspension also add to this.
Old Jun 14, 2004 | 02:43 PM
GY-Z's Avatar
GY-Z
can u be more specific?
what in the suspension setup make it under?
Old Jun 14, 2004 | 02:44 PM
GY-Z's Avatar
GY-Z
what kind of weight distribution leads to understeer?
like a heavier rear?
Old Jun 15, 2004 | 10:33 PM
BulletproofRich
Generally speaking, a heavier nosed car will exhibit more understeer, as the weight will overcome the tires ability to grip at some point. Understeering is relatively easy to recover from in panic situations (Just not as fun as oversteering =D)
Softer spring rates add a lot to the understeering. weight over/in front of the front axle. Alignment settings can add to it. Swaybar sizes. Tires. Vehicle Weight. there are many different variables that are present in understeering.
Old Jun 15, 2004 | 11:10 PM
ares's Avatar
ares
Veteran
staggared tires arent helping either.
Old Jun 16, 2004 | 12:12 AM
DuckyZgiirl's Avatar
DuckyZgiirl
What in-between understeer and oversteer?
Old Jun 16, 2004 | 10:54 AM
GY-Z's Avatar
GY-Z
so theoritically speaking, adding weight on the rear will help understeer?
Old Jun 16, 2004 | 12:56 PM
Kuzmeista's Avatar
Kuzmeista
just make your suspension stiffer... it will compensate for a lot...
Old Jun 16, 2004 | 09:24 PM
shortcut3d's Avatar
shortcut3d
On the Z and G35C the stagger tire setup is alot of the reason for understeer.
Old Jun 16, 2004 | 11:12 PM
GY-Z's Avatar
GY-Z
there are other FR car thats with stagger setup also, how come they oversteer instead of understeer?(ie, supra)
changing ur tire setup to a non stagger setup will help the understeer for sure, but that doesn't mean the stagger setup is a lot of reason for understeer which happened in g or z?
Old Jun 16, 2004 | 11:13 PM
GY-Z's Avatar
GY-Z
i just want to make a disscussion about the understeer issue.
not how to fix it.
but thanks for the openion anyways.
hardwood66
Sep 8, 2015 04:31 AM
Brad4rdHay
Mar 27, 2003 06:57 AM
AndyB
Mar 9, 2003 07:35 PM
moab355
Jan 3, 2003 03:30 PM
Flyingscot
Nov 27, 2002 12:04 PM
