stock tranny and clutch strength
Old Jan 15, 2005 | 10:13 PM
texasranger2003's Avatar
texasranger2003
Default stock tranny and clutch strength
Assuming the engine is strong enough to withstand a well tuned FI system, how about the transmission and clutch? Can these stock components handle up to 400whp? What other parts could be negatively affected by the increased power?
thanks
Old Jan 15, 2005 | 10:53 PM
bascelik's Avatar
bascelik
At 400+whp, as far as I've learned on this forum, you should consider a built motor (rods, pistons, ...) and aftermarket clutch.
Old Jan 16, 2005 | 09:19 AM
G3po's Avatar
G3po
Default Re: stock tranny and clutch strength
thanks
tranny yes ,unless you abuse the **** out of it
and clutch yes "for a while", but it will start slipping sooner than later.
There are many inexpensive clutch choices , Clutchmasters Stage3 and JWT to name few that are fine for this power level.
Depending how hard you drive , all driveline parts , ie Diff , half shafts etc etc. are effected by the increased rwhp. Repeated hard drag launches (especially with slicks) will eat there lunch the fastest.
If you launch like granny on street tires , all these components should last a long while.
Old Jan 16, 2005 | 10:07 AM
LOU's Avatar
LOU
415rwhp on stock clutch for 6000 miles and counting. No transmission problems either.
Old Jan 16, 2005 | 10:52 AM
dansouliere's Avatar
dansouliere
I am still waiting for somebody to buy a set of half shafts from Drive Shaft Shop.
http://web.inetba.com/dss/item158471.ctlg
I wonder how well they are designed.. They call it the 350ZX so if they don't know the actualy name of the car it makes me wonder.. lol
Old Jan 16, 2005 | 11:10 AM
g356gear's Avatar
g356gear
I believe mjedens has a set that he runs for nitrous with his built motor. No problems with slicks anymore.
Old Jan 16, 2005 | 12:22 PM
ZZZ-35's Avatar
ZZZ-35
380rwhp 3200 miles and the clutch is now starting to slip after this weekend's meet, new twin plate to be install ASAP.
Cheers
Old Jan 19, 2005 | 11:35 AM
mcduck's Avatar
mcduck
425rwhp and 15000 miles on motor since supercharging.
Did not really "feel" the clutch was slipping, but recently Nissan replaced my tranny for known synchro issue (again!) and put a new redesigned clutch in the car. It became quickly obvious that my old clutch was slipping and probably had been for quite some time.
Now waiting on JUN flywheel so I can put it and a CM III in the car next month.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
