WTF!!! Just dynoed....woooooooah!!!
Old Apr 19, 2005 | 05:45 AM
  #81
sselway's Avatar
sselway
You must either be rich or not have a girlfriend/wife to drop that kinda money on car mods. Although I read a magazine article that said gay couples have some of the highest disposable incomes...
Mind if I ask what you do for a living?
Old Apr 19, 2005 | 06:36 AM
  #82
350zDCalb's Avatar
350zDCalb
builtZmotors
it's probably true that GERMAN gay couples have some of the highest incomes
I do have a girlfriend...and I am a chiropractor(DC) hence "350zDC"
Old Apr 19, 2005 | 02:50 PM
  #83
LittleMT's Avatar
LittleMT
Originally Posted by IceY2K1Max
Not yelling...just stressing the points intermixed with the rest of the BS. There isn't one for FI guys...that I know of. However, if a NA vehicle would lose 21% of rated power in your area, then assuming a CF of ~1.266 would mean your 603whp corrected is about 476whp uncorrected NOT including adding back temp/humidity/compressor efficiency loss.
All you should correct for is temp/humidity...maybe 2-3%(ignoring IC benefits)...then to more accurately adjust, add 1-2% loss for compressor efficiency(2nd or 3rd efficiency island), since your turbos are spinning faster to produce the SAME 16psi. If we say a 5% max correction is necessary, you'd take 476whp and correct temp/humidity/eLoss to ~500whp.
Whatever you choose, the UNcorrected numbers/chart would be FAR closer to what your "real world" numbers would be. Anytime you *ADD* 100whp or more to your uncorrected numbers via a correction factor, that should make you question/think why.
Any way you slice it, your car at sea level wouldn't hit much over 500whp@16psi, most likely, so people trying to compare your dyno to theirs aren't going to be comparing apples-to-apples and will be asking WHY. It is unfair for you slightly to not correct for the temp/humidity and some compressor efficiency loss, however it is far more unfair to compare your SAE inflated numbers against others.
Any chance you'll be taking it to the track?
Here is some food for thought mr. Tuscon....
At the same Dyno my car at that time made 481hp and 499ft tq.
Ever hear of AGP turbo in the Phoenix area? They had a similar equiped shop car over there dyno 490hp and 497ft tq.
Now, what is the elevation at Firebird Raceway? 1100ft? So they are still not quite sea level.
They ran there car at the track and I ran mine...
AGP ran a 11.7 and trapped 125mph, my car ran a 11.8 and trapped 124.5mph.
The track they used is far better then ours.
Our sae numbers and track times equaled AGP, and the air density was 6500ft when my car went 11.80... hows that for 'real world numbers' as you put it?
And this wasn't a matter of me running more boost, as I ran as much boost as my 50 trim turbo would flow both on the dyno and at the track....
again AGP in the Phoenix metro area isn't sea level and even their dyno used correction factors however they should be closer to sea level numbers then me, obviously, yet we made similar numbers and ran similar times.
The correction factors used at the dynos edge (which I don't know exactly what they are) have proven to be pretty darn accurate time and time again.
They had a turbo mustang make 500hp, this mustang then went and dynoed in Los Angeles California a week later and was actually 5hp higher then the sae numbers from dynos edge.
The numbers posted by Todd and Ernie are fabulous, congratulations fellas....
Since you 2 had dynoed at Dyno's Edge before, regardless of SAE numbers, you both still saw some nice gains with more boost, which is to be expected.
I encourage you two to tread with caution, as these power levels will reveal other weak links in the car. Good luck!
Old Apr 19, 2005 | 02:53 PM
  #84
LittleMT's Avatar
LittleMT
we have actually witness Todd working several busy intersections with a large sign, crappy clothes, and a dirty unshaved look.
The sign he had said,
"Will Work For Boost"
Old Apr 19, 2005 | 03:56 PM
  #85
going deep's Avatar
going deep
Hey, thanks for the props!
As mentioned before, I will be doing a dyno retune in Chicago, according to a google search is at ~600 Feet above sea level. The first run I am going to do is at the same boost I have here in Alb. That would be another "real world number" test!
Old Apr 19, 2005 | 06:05 PM
  #86
350zDCalb's Avatar
350zDCalb
builtZmotors
thank god someone finally chimed in who has some comparisons here with a turboed car--THANKS LU!!! good to hear some FACTS
Bottm line...the car is frickin fast!!! if this guy wants to get his panties in a knot because whatever whatever--good for him...the car is fast...i guestimate it doesn't lose the 18% that the NA cars do up here...the only way i would know is to go dyno at sea level w/ the same boost--that won't happen anytime soon.
Old Apr 19, 2005 | 06:06 PM
  #87
350zDCalb's Avatar
350zDCalb
builtZmotors
Talking
LMAO!!!
i can make pretty good money on the streets- i guess i have the face that people feel sorry for!
Old Apr 19, 2005 | 07:00 PM
  #88
Gman2004's Avatar
Gman2004
This car is da ****......looks like there are a couple of jealous people on this thread.
Old Apr 19, 2005 | 07:25 PM
  #89
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
A Z right here in chicago (~600ftmsl) hit 511rwhp on 11psi a few months ago...how do you figure that a Z with 16psi fully tuned wouldn't make any better numbers?
Old Apr 19, 2005 | 07:58 PM
  #90
350zDCalb's Avatar
350zDCalb
builtZmotors
Default a little green monster is coming out...
thank you thank you
so, mr tuscon (as little MT named you)...i think your number is up
Old Apr 19, 2005 | 08:10 PM
  #91
LittleMT's Avatar
LittleMT
Originally Posted by 350zDCalb
thank you thank you
I mean't to say Tucson, as in Tucson AZ, as in were he is from. I was figuring he is probably aware of AGP turbo whom is in neighboring Phoenix...
Old Apr 19, 2005 | 08:11 PM
  #92
phunk's Avatar
phunk
CJ Motorsports
Todd I am very happy for you that your project is working out.
This was on all done on the prototype crank trigger wire wired how I told your tuner, correct?
Old Apr 19, 2005 | 08:14 PM
  #93
350zDCalb's Avatar
350zDCalb
builtZmotors
yah man!!! thx again..couldn't have done it without you (or at least--i could have done it ,, but would have been paranoid that some irradic signal from the crank angle sensor was gonna blow my forged motor---now i sleep better at night!)
Old Apr 19, 2005 | 08:32 PM
  #94
350zDCalb's Avatar
350zDCalb
builtZmotors
yah...i gotchu...i just wanted to use the same reference (i didn't want to try to type out his screen name)
TODD
Old Apr 20, 2005 | 08:14 AM
  #95
ZRAYGO's Avatar
ZRAYGO
Yea, its official. I am jealous. But not because of the car, but because of the tuner. Why cant I find a tuner that can get me over the hump? Can anyone help me out here, give me some suggestions before I poor another 5-6k into the dam thing? I have one other plan of action, but before I get into that I want to exhaust all o fmy possibilities here in california.
HELP A BRUTHA OUT PLEASE!!!
Old Apr 20, 2005 | 12:12 PM
  #96
going deep's Avatar
going deep
WooHoo Charles, see you in 12 days for a sealevel retune!
Old Apr 20, 2005 | 01:55 PM
  #97
350zDCalb's Avatar
350zDCalb
builtZmotors
ummm ernie...use your own damn thread--- or pm
if u break these rules again, you will be destroyed
Rev_Night
Nov 7, 2020 06:00 PM
350z_z33.
Jul 3, 2017 04:01 AM
cashmoney03
Sep 27, 2015 05:24 PM
DURSO
Southern California
Jul 25, 2003 01:51 PM
DURSO
Jun 19, 2003 09:57 AM
